SubieJake Posted February 1, 2021 Share Posted February 1, 2021 So a few days ago I blew a rod on my 2007 legacy gt, it was only a matter of time. this is my daily driver so I’ve been trying to find a direct drop in because I just don’t got the funds and time to do a full rebuild and swap etc etc... So this 2005 forester xt has popped up and he’s willing to give me the full car for a good price because he needs it out of his shop... Now my question is, will a 2005 forester xt engine drop straight into my 2007 legacy gt? I’ve been trying to look for an answer and I’m getting mixed ones, it’s mostly because I’m not sure if the 05 xt would be a direct swap for the 07 legacy, I’m pretty sure it’s the same as the 06 legacy gt, but Through my research I couldn’t find a direct answer. I just don’t want to buy the car and realize there’s multiple modifications I have to do to get it back on the road. Sorry if there’s a post about this already but I’ve been trying to research and couldn’t find a direct answer for my situation Link to comment Share on other sites More sharing options...
tysparks81 Posted February 1, 2021 Share Posted February 1, 2021 The shortblock is going to be the same, you need to swap your intake manifold onto the XT motor & you would use your stock top mount and wire harness, but everything else should bolt up. #LGTSTi is still cheaper and nicer then an equal year wrxsti Follow my 2007 Spec B. Build here Link to comment Share on other sites More sharing options...
Max Capacity Posted February 1, 2021 Share Posted February 1, 2021 Is your a 5mt or 5eat tranny ? The 5mt engines have two guides in the upper corners of the timing belt covers that 5eat's don't require. You can keep them when you use that engine on a 5eat, but if you get the engine from a automatic car you will have to add the guides to put that engine in a 5mt car. The guides help keep the belt in place when you push in the clutch from high rpm's. http://people.csail.mit.edu/ilh/vacation/ There's the service manual if you need it. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
SubieJake Posted February 1, 2021 Author Share Posted February 1, 2021 Is your a 5mt or 5eat tranny ? The 5mt engines have two guides in the upper corners of the timing belt covers that 5eat's don't require. You can keep them when you use that engine on a 5eat, but if you get the engine from a automatic car you will have to add the guides to put that engine in a 5mt car. The guides help keep the belt in place when you push in the clutch from high rpm's. http://people.csail.mit.edu/ilh/vacation/ There's the service manual if you need it. Thank you they are both 5speed manual i looked at the forester today and its the ej255 ab440 now i have the 07 legacy gt which is a ej255 ab630 would that be compatible? and if so what would you have to do too make it compatible? Link to comment Share on other sites More sharing options...
Max Capacity Posted February 1, 2021 Share Posted February 1, 2021 See post #2 for that answer. The short blocks are the same. It's just your cars bolt on's that you should use. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
B-BGTLimited Posted February 2, 2021 Share Posted February 2, 2021 (edited) If you haven't done the air pump delete on your 07 yet you'll have to do it with the 05 motor. You'll only have to follow the instructions on how to get the ambient air pressure sensor to still work. The heads are different between the 07 and 05 so if you're using more than the short block you'll need to keep that into consideration. Sent from my Pixel 4a using Tapatalk Edited February 2, 2021 by B-BGTLimited Link to comment Share on other sites More sharing options...
