Tsunamijedi_ Posted August 31, 2020 Share Posted August 31, 2020 Hi all, so I just removed the banjo bolt filter for my turbo oil feed line on my 05 legacy gt, and when I removed it some oil spilled out onto the up pipe, after reinstalling it I boosted it around the block, and when I came back there was white smoke coming from the passenger side of the engine, around/under the head gasket area, I suspect it could be the oil on the up pipe burning up? If it was would it smoke like that? Link to comment Share on other sites More sharing options...
dwmccauley01 Posted August 31, 2020 Share Posted August 31, 2020 Yes, oil on exhaust will cause white smoke. Drive it more and see if it goes away. Also check and make sure oil is not leaking from the banjo bolt. Sent from my SM-G970U using Tapatalk Link to comment Share on other sites More sharing options...
dgoodhue Posted September 6, 2020 Share Posted September 6, 2020 Yes, oil on exhaust will cause white smoke. Drive it more and see if it goes away. Also check and make sure oil is not leaking from the banjo bolt. This double check for leaks, hopefully you aren't missing banjo bolt washer. Link to comment Share on other sites More sharing options...
