o2 sensor question
Say, if i just have the headers without catback, so the exhaust is exposed right after the second o2 sensor, wouldn't this unviable? For take a look at this picture; clearly the sensor is prone to sensing oxygen from the atmosphere and not the exhaust.
But another question is that since this is a catless header with just empty flexpipe between the two sensors, is there really a difference between the two?
appreciate any input; thanks
Yes, there is a difference, the two sensors do different things.
The front one is used to meter fuel.
A Tuner can delete the second/rear sensor.
Engine Build - Click Here
