RSK LIMITED II Posted August 22, 2020 Share Posted August 22, 2020 After letting my car sit for about 2 or 3 weeks I finally got it started again only to realise that there was smoke coming from the drivers side of the engine bay. Never used to have this issue before. When idling cold doesn’t have the issue but when the warms up it seems to occur. Not sure if smoke is oil or not as doesn’t have that typical burning oil smell. Smoke seems to be coming from the area where the turbo on drivers side. (Right hand drive) is located. Unsure if it is related to turbo as I can’t exactly pin point where alter smoke is coming from as it seems to be coming from somewhere deep down but unsure. Thoughts ? 2002 subaru legacy ej208 twin turbo ( smoke from left hand side of circle on picture provided Attached Thumbnails Also unsure if related or not my mate jumped the car but put leads wrong way around. car still tuns and goes hard just smoke which is new issue. Unsure if this could be related or not Link to comment Share on other sites More sharing options...
DaveWaters Posted August 22, 2020 Share Posted August 22, 2020 Smoke in that area could be a number of things. Since it was sitting a while it could be a valve cover leak. Another common cause is a torn cv boot. The inner boot near the up pipe is the one most likely to go first and throw grease on hot metal (at least on the gen4 lgt). Ideally you need to get under the car and have a look. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 22, 2020 Share Posted August 22, 2020 Have a good bright light with you when your under the car looking up at the area. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
