Lttlwing16 Posted August 19, 2020 Share Posted August 19, 2020 is it possible to remove all the old fluid from the master cylinder reservoir? It seems there is a divider that I can't get the fluid out from. I'm trying to use the gravity drain method, but it seems that old fluid behind the reservoir isn't budging. I even have my wife come out and pump the brake a couple times while I opened and closed the bleeder screw. Here's a cross post from Reddit: Link to comment Share on other sites More sharing options...
Grnlantern1 Posted August 19, 2020 Share Posted August 19, 2020 is it possible to remove all the old fluid from the master cylinder reservoir? It seems there is a divider that I can't get the fluid out from. I'm trying to use the gravity drain method, but it seems that old fluid behind the reservoir isn't budging. I even have my wife come out and pump the brake a couple times while I opened and closed the bleeder screw. Here's a cross post from Reddit: You might get a Vacuum Brake bleed kit from Harbor Freight or Auto Parts store and bleed your brake that way. Basically you hand pump the pressure up and open the bleeder and it pulls out the fluid from the resevoir.. Just make sure you keep your reservoir full so no air enters yhe system. Sent from my SM-G988U using Tapatalk Link to comment Share on other sites More sharing options...
Lttlwing16 Posted August 19, 2020 Author Share Posted August 19, 2020 You might get a Vacuum Brake bleed kit from Harbor Freight or Auto Parts store and bleed your brake that way. Basically you hand pump the pressure up and open the bleeder and it pulls out the fluid from the resevoir.. Just make sure you keep your reservoir full so no air enters yhe system. Sent from my SM-G988U using Tapatalk Thanks for the input! The gravity drain worked great apart from being unable to aspirate the older fluid from behind the divider. I work in healthcare and was able to use a drain bag we use for certain surgical drains. Worked like a charm. Here's the exact one I used. (https://www.amazon.com/dp/B013TLIC1U/ref=cm_sw_r_cp_apa_i_pMBpFbCMH1Q8B) From what I'm reading the separated reservoir is part of the dual braking system as a second reservoir that is filled from the front reservoir. It's part of a redundant system so the whole system doesn't lose pressure That said still haven't seen anywhere that it can be manually drained,apart from unhooking the brake lines from the master cylinder. Which I'm not messing with to just change the fluid. Link to comment Share on other sites More sharing options...
Max Capacity Posted August 20, 2020 Share Posted August 20, 2020 You might get a Vacuum Brake bleed kit from Harbor Freight or Auto Parts store and bleed your brake that way. Basically you hand pump the pressure up and open the bleeder and it pulls out the fluid from the resevoir.. Just make sure you keep your reservoir full so no air enters yhe system. Sent from my SM-G988U using Tapatalk That is your best option ^ Or just bleed the brakes with someone in the car until fresh fluid comes out at each wheel. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
aki334 Posted August 22, 2020 Share Posted August 22, 2020 next time do this: Cheap and very effective, just keep adding new oil to reservoir to flush out old. Link to comment Share on other sites More sharing options...
chowser51 Posted August 22, 2020 Share Posted August 22, 2020 Not for Subaru but I used a Motive bleed kit on my bmw. Was very quick and easy. Brake fluid was $11 for the bottle. Link to comment Share on other sites More sharing options...
