samuel082799 Posted June 17, 2020 Share Posted June 17, 2020 These are ev14 to denso injector adapters for deatschwerks injectors. Brand new, never used. Looking for $40 plus shipping. Sent from my Pixel 2 using Tapatalk Link to comment Share on other sites More sharing options...
SonoftheBread Posted June 23, 2020 Share Posted June 23, 2020 Are these actually required for running Deatchwerks injectors on a GT? I picked up some 850 side feeds a while ago for my build. Link to comment Share on other sites More sharing options...
samuel082799 Posted June 24, 2020 Author Share Posted June 24, 2020 Are these actually required for running Deatchwerks injectors on a GT? I picked up some 850 side feeds a while ago for my build.It is supposed to adapt your denso plugs to the ev14 style plug used on deatschwerks injectors. If your car is a factory side feed injector car (2005 to 2006) these won't work. The connector for side feeds is different from top feeds, that's why I'm selling them because my car is a 2005. Sent from my Pixel 2 using Tapatalk Link to comment Share on other sites More sharing options...
rhino6303 Posted June 24, 2020 Share Posted June 24, 2020 It is supposed to adapt your denso plugs to the ev14 style plug used on deatschwerks injectors. If your car is a factory side feed injector car (2005 to 2006) these won't work. The connector for side feeds is different from top feeds, that's why I'm selling them because my car is a 2005. Sent from my Pixel 2 using TapatalkThey technically can work on a side feed car if you trim the tabs on the side of the connector on the conversion harness. Link to comment Share on other sites More sharing options...
samuel082799 Posted June 25, 2020 Author Share Posted June 25, 2020 They technically can work on a side feed car if you trim the tabs on the side of the connector on the conversion harness.I wish I new that earlier [emoji23][emoji23] Sent from my Pixel 2 using Tapatalk Link to comment Share on other sites More sharing options...
