ObsidiousGT Posted May 26, 2020 Share Posted May 26, 2020 I am considering getting the pro kit to pair with my KYB Excel-g struts. The KYB’s are not my favorite(feel like stock) but since I already have them on my car I want a suitable spring. My questions are, which ones do I need to get? Are there better options? Thoughts? Link to comment Share on other sites More sharing options...
Notorious Posted May 26, 2020 Share Posted May 26, 2020 I recommend H&R’s over Eibach, personally. I ran them with the same struts. I sold them to GEE-OTTO if he wants to chime in. Link to comment Share on other sites More sharing options...
Pleides Posted June 1, 2020 Share Posted June 1, 2020 What car we working with here, to start with? KYBs won't last long with a spring that drops as much as the H&R (about 1.4 inches in the front). Here's my car with Konis and H&R springs. STi pinks are a common recommendation with stock shocks because they don't drop super low and feel like a nice upgrade in the handling department. They're a little expensive given the fact that they're from Japan, but here's a link. Alternatively, if you wanted a better ride with a lowering spring and better shock longevity, you could get Koni cut-a-struts like my car has. Since you just bought the shocks, I'm guessing you don't wanna feel like you wasted all that money, which is fair. Link to comment Share on other sites More sharing options...
awfulwaffle Posted June 1, 2020 Share Posted June 1, 2020 Someone happens to be selling a set of Konis with Eibachs in the 4th gen FS section.... Link to comment Share on other sites More sharing options...
ObsidiousGT Posted July 12, 2020 Author Share Posted July 12, 2020 I'm starting with a 2006 LGT M. Since I bought them recently, I am going to keep the KYB's until they blow then replace them with something better. I think I am pretty committed to the Pro Kit but I am not sure which set to buy. When I do searches I can't find a set for my year LGT. Link to comment Share on other sites More sharing options...
m sprank Posted July 17, 2020 Share Posted July 17, 2020 Discontinued LONG ago. Not a lot of options anymore. H&R is probably the best of whats left. Link to comment Share on other sites More sharing options...
ObsidiousGT Posted July 20, 2020 Author Share Posted July 20, 2020 Do you know what size rear spacer I would need to avoid saggy butt syndrome with the H&Rs? Link to comment Share on other sites More sharing options...
m sprank Posted July 21, 2020 Share Posted July 21, 2020 With a standard LGT sedan, none. Saggy butt is caused by the thicker front SpecB top hats and wagons using sedan springs. Wagon rears are heavier (more glass) than sedans. Link to comment Share on other sites More sharing options...
Pleides Posted July 21, 2020 Share Posted July 21, 2020 My wagon has a 3/8 inch spacer and a pretty even rake. 1/4” would probably get you by better though. Little too much wheel gap with the 3/8” IMO. Link to comment Share on other sites More sharing options...
Max Capacity Posted July 21, 2020 Share Posted July 21, 2020 (edited) My wagon has 3/8" spacers, I just checked on the GB thread, happy with it. https://legacygt.com/forums/showthread.php/2nd-annual-group-buy-epic-springs-05-09-lgt-212865p3.html Post # 106 Read the comment in post 161. Still feel way about this set up. Here's the car with Conti' DWS 225/45-17's. Edited July 21, 2020 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
