SEMA Built Cusco 2005 Legacy GT Wagon (SoCal)
uzubair
Ok Members,
The time has come for me to release this beauty to a new owner. This car was originally built for the SEMA show with collaboration with Cusco Suspension. It is a full subframe off restoration with every bushing replaced and control arm powder coated (See pictures). All aftermarket parts I have will come with purchase of car. Rare Limited Wagon with black interior and has always been garage kept. Extremely taken car of and as I have babied this car since I bought it. It has won many shows including Best of Show at Subiefest. It was also featured in Pasmag:
https://www.pasmag.com/features/vehicle-features/on-point-2005-subaru-legacy-25-gt-wagon
More Pictures: https://img.nasioc.com/uzubair
Year, Make and Model: 2005 Subaru Legacy GT Limited Wagon
Color: Metallic White Pearl
Miles: 62k
Transmission: 5EAT
Title: Clear
Lien: No liens
VIN: 4S3BP676654315080
Seller's email address: info@riamu.com, PM me if necessary
Asking Price: $29,500 (OBO)
Engine Compartment:
• JDM Stance ABS Cover
• JDM Stance Battery Cover
• Cusco Upper Strut tower bar
• Color Matched Subaru Engine Cover
• Cusco Radiator Heat Shield
• Nitrous Express Nitrous Oxide System with bottle in trunk
• Power Coated Cusco Blue Radiator brackets
• Power Coated Cusco Blue Hood Stay bracket
• Optima Yellow Top Battery
• Cusco Oil Catch can
• SPT Oil Cap
• SPT Battery Tie down
JDM Balsarini Front Bumper with JDM bumper beam -(ONLY ONE IN NORTH AMERICA)
• JDM Balsarini Rear Bumper with JDM Bumper beam -(ONLY ONE IN NORTH AMERICA)
• R-Rev Carbon Fiber Sprats
• JDM Tail Lights
• Modern Image One off Custom Graphics
• 19x8 SSR Comp-H Wheels (comes with 5 wheels)
• Work wheels lug nuts
• Falken Tires 452 235/35/19
• Magnaflow Catback Exhaust (for sedan because of short JDM bumpers)
• Custom rolled and pulled fenders
Suspension
• Cusco Zero 2E Coilovers with upper pillow mounts
• Cusco E-Con Controller
Cusco Front Sway Bar (23mm)
• Cusco Rear Swar Bar (21mm)
• Cusco Sway Bar Linkage Front and Rear
• Cusco Exhaust Bushings
• Cusco Version 2 support bar
• Cusco Floor Front Side support bar
• Cusco Floor Center support bar (Right and left)
• Cusco Floor Rear side Support bar
• Cusco Version 1 support front bar
• Cusco Upper rear Strut tower bar
• Whiteline Anti lift kit
• Whiteline Differential Mount Bushings
• Whiteline Front Inner Control Arm Bushings
• Whiteline Positive Shift Kit
• Whiteline Rear Differential Bushings
• Whiteline Roll-Center & Bump-Steer Complete kit
• Whiteline Steering Rack Bushings Kit
• Whiteline Subaru Legacy GT Camber Adjustment Kit
• Whiteline Subaru Legacy GT Adjustable Rear Control Arm Kit
• Custom powder coated Cusco Blue Controls Arms, Rear Center bracket,
etc..too may pieces to list. Entire under carriage is custom coated candy blue.
Brakes:
• Rotora Street Challenge Front
• 6 Pistons Forged Calipers Metallic Blue
• 355mm 14in 2 piece oversize heated treated Slotted and Drilled Discs
• Stainless Steel Braided Brake Lines
• T-Billet 7075 Grade Mounting Brackets
• H2 Ceramic Formulated pads
• Rotora Street Challenge Rear
• 2 Pistons Forged Calipers Metallic Blue
Interior
• Nardi Classic 330mm Steering Wheel
Works Bell Rapfix GTC System
• Works Bell Subaru small Hub
• Bride Cuga with Gradation Fabric Left and Right racing Seats
• Bride Seat Brackets for Subaru BP5
• Bride custom upholstery Gradation Fabric rear seats
• Bride custom upholstery Front and Rear Doors
• Takata 4pt racing harnesses (left and right) long
• 52 mm STRI- DSD White Dial Boot Gauge
• 52 mm STRI- DSD White Dial Water Temp Gauge
• 52 mm STRI- DSD White Dial Oil Temp Gauge
• 52 mm STRI- DSD White Dial Oil Press Gauge
• 52 mm STRI- DSD White Dial Exhaust Temp Gauge
• 52 mm STRI- DSD White Dial Voltmeter
• Custom shift and e-brake boot
• JDM HVAC system
• JDM Hazard light Switch
• JDM custom painted center surround unit to match HVAC
• Razo RA 25 Onyx 340g gear shift knob
• Razo Formula Spec RP 112 pedals, including dead pedal
• Carbon Fiber center console surround
• Carbon Fiber front and rear door handles
• Off Black Subaru interior carpet
• Off Black Subaru rear passenger seat belts
• Custom Subaru black matched interior (including dash, doors, rear section,
door sills, etc)
• Subaru Black door sills (front and rear)
• Subaru black door weather strips
I.C.E (In Car Electronics)
• Clarion NZ502 Head Unit with Navigation (Advanced Demo Unit) not
available for custom purchase
• (2) Polk Audio MM 5251 (5 1⁄4 ) Components including tweeters (in all four
doors)
• (1) Polk Audio MM 5251 (5 1⁄4 ) Components including tweeters (in custom
kick panels)
• (1) Polk Audio MM 521 (5 1⁄4) Coaxials in custom build back hatch section
• (3) Polk Audio MM 1240-DVC Dual 4-Ohm Voice Coil 12" Subwoofers
• (2) Polk Audio D4000.4 High performance Digital Car Amplifier
• (1) Polk Audio D1001.1 High performance Digital Car Amplifier
• Custom Built Door Panels with LED around components
• Custom Built Fiber Glass subwoofer box
• Custom Built Amp Rack with LED lit plexiglass
• Custom Built Nitrous Bottle Rack with LED lit plexiglass
• Custom Built Sponsor board with LED lit Plexiglass
• Custom Built Subwoofer Plexiglass Cover LED lit
• Dynamat Sound reduction solution (Entire Car)
• Monster Power and speaker cables
• Monster Terminal Battery Connectors
Edited by uzubair
With Pictures
Holy freakin unicorn! So stock motor with nitrous? Sounds scary :) crazy parts list! Seller the roll cage in you car appears to be bolt in correct? Assuming it’s built right for actual use on track, if the buyer is interested, I’d be interested in potentially buying it to put in my ‘05 GT wagon track car :) Edited by shralp
Hi Shralp,
Yes, I built the car completely for show purposes. Basically a stock motor that is spotless. The roll cage does not come with car. I have already removed it since there was only one ever made by Cusco for the SEMA show. We removed it for liability reasons. It should not be listed on my parts list. It does also comes with all stock parts I have and 3 sets of wheels comes with purchase of car. Feel free to DM me and we can talk via phone if you want more history on the car.
Boy that would be a great replacement for my wagon...I'm might need a wagon to take me to VT each winter weekend for skiing...;) Mine just rolled 289,000 miles today.
Very nice looking car. Good Luck with the sale.
Engine Build - Click Here
Thanks... Let me know, it would be one hell of a ski/snowboard hauler. :lol::lol:
  • 2 weeks later...
  • 3 weeks later...
