Libertarian Posted January 15, 2020 Share Posted January 15, 2020 (edited) I am absolutely dying from this rattle that happens above the right rear passenger that only seems to occur when the sunroof blind is open. Even closing it half way is enough to silence it. But strangely enough the noise can sometimes happen when it's shut but I think I'm just getting delusional. Anyways with the sunroof blind open even banging on the ceiling will cause the rattle so it's definitely there. Something with the curtain airbag I'm assuming? Please tell me somebody has had this and resolved it! Heeeelp! Edited January 15, 2020 by Libertarian Link to comment Share on other sites More sharing options...
bookem288 Posted January 15, 2020 Share Posted January 15, 2020 I had that happened too. It was the rubber curtain that came out of its track when the sunroof slid back to the open position. It was easy to put back in. Link to comment Share on other sites More sharing options...
andrelaplume Posted January 15, 2020 Share Posted January 15, 2020 I had a similar issue....the rubber needed to be lubed. Subaru took care of it. It's back after 6 months. It was just mosiy enough to be heard with the thing slid open...do not hear it when the cover is closed Link to comment Share on other sites More sharing options...
Libertarian Posted January 16, 2020 Author Share Posted January 16, 2020 I had that happened too. It was the rubber curtain that came out of its track when the sunroof slid back to the open position. It was easy to put back in.Teach me! I need more details! Link to comment Share on other sites More sharing options...
Libertarian Posted January 16, 2020 Author Share Posted January 16, 2020 I had a similar issue....the rubber needed to be lubed. Subaru took care of it. It's back after 6 months. It was just mosiy enough to be heard with the thing slid open...do not hear it when the cover is closedSo the railing? Link to comment Share on other sites More sharing options...
andrelaplume Posted January 17, 2020 Share Posted January 17, 2020 Simply lubing the thick rubber gasket around the opening solved the issue....for a few months anyway. The car is sadly a rattletrap. Link to comment Share on other sites More sharing options...
capttris Posted January 22, 2020 Share Posted January 22, 2020 What product did you use for lube? I have this problem on my 2013 sunroof. thanks Link to comment Share on other sites More sharing options...
Brisvegas Posted January 22, 2020 Share Posted January 22, 2020 What product did you use for lube? I have this problem on my 2013 sunroof. thanks I have used Meguiars Natural Shine Protectant every couple of months from day one and never had a problem ... IMHO any similar protectant would do the job. Link to comment Share on other sites More sharing options...
Libertarian Posted January 22, 2020 Author Share Posted January 22, 2020 Simply lubing the thick rubber gasket around the opening solved the issue....for a few months anyway. The car is sadly a rattletrap.The noise is inside the car though or have I misunderstood Link to comment Share on other sites More sharing options...
