darthqwo Posted January 7, 2020 Share Posted January 7, 2020 (edited) i am looking for a cap to substite an oil filter at the bottom of the engine. Web search begets a cap fits onto the filter itself, but I am looking for one to fit onto the engine block southside; or if there is a low-profie oil filter. omg thanks Edited January 7, 2020 by darthqwo Link to comment Share on other sites More sharing options...
Max Capacity Posted January 8, 2020 Share Posted January 8, 2020 Sounds like you have a external oil filter set up ? Or why would you need to remove the oil filter and plug the holes ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Nonamedude Posted January 8, 2020 Share Posted January 8, 2020 I don't remember the threading for the bolt hole but why not just use a big bolt. Whatever the pitch of the bolt used to hold on the oil cooler. And that's aside from the question of why. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Max Capacity Posted January 8, 2020 Share Posted January 8, 2020 Hey buddy you seem to forget there is the oil return hole that needs to be capped...which isn't threaded. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
darthqwo Posted January 9, 2020 Author Share Posted January 9, 2020 (edited) i have another thread entitled turboing 2.5i but got no replies cause i bashed lgt owners. Correct; that would be the oil return hole; it needs an actual filter or pseudo filter; i am plumbing the oil feed through a sandwich plate, but a filter wouldn't fit with the regular wrx manifold. so i don't think i need to do this anymore, but i was thinking of deleting the oil filter. the turbo is the 2015 wrx turbo, but the fourth gen wrx does not have an oil filter in the south. I actually have a bigger issue than this, that being a the 6.5 inch ej25 oil pan the fa20dit manifold won't fit over without extensions. also, if anyone wants to know i am planning to put in a 4.5" aluminum oil pan with a tomei baffle Nonetheless, I will need extensions at the flange that I will have to weld pipes to or just stack flanges; i just don't want 3-inch extensions at the flange Edited January 9, 2020 by darthqwo Link to comment Share on other sites More sharing options...
Max Capacity Posted January 9, 2020 Share Posted January 9, 2020 Is there a reason you can't use the exhaust manifold from a 2010-2012 Legacy GT ? that would mount the turbo down low up front. Same basic 2.5 shortblock ... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
darthqwo Posted January 9, 2020 Author Share Posted January 9, 2020 wow i didn't realise fifth gen lgt has the same manifold as the 2015 wrx. i did look, though, at the fifth gen legacy oil pan, but ti is different with less screw holes than the regular ej25 pans; do you know how to make it fit on the regular ej25 motor? omg thanks! Link to comment Share on other sites More sharing options...
Max Capacity Posted January 9, 2020 Share Posted January 9, 2020 I have no idea, if it will fit, I was just asking if you had checked it ? You may have other clearance issues if there's a big difference in the 5th gen chassis in that area. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
darthqwo Posted January 9, 2020 Author Share Posted January 9, 2020 so i looked into it, and it is a fascinating note, tolland--omg thanks; this adapts the oil pan for the new fa20 manifold to the ej25 short block; it is like one of those intermediary dinosaurs that go extinct between the main dinosaurs. So it is a two-piece oil pan and on ebay you only see the lower part of the pan, which you'd think is the whole pan; but it is not! i just need to check the oil pickup flange mounts the same way, but with this it sure saves a lot of money compared to the other idea Link to comment Share on other sites More sharing options...
darthqwo Posted January 10, 2020 Author Share Posted January 10, 2020 the turbo manifold for the 2010-2012 legacies has a different mounting bolt pattern to the turbo than the fa20 manifolds but has otherwise mostly the same shape; i figure this is good to note. (the nonturbos for those model years use the regular exhaust manifold but they all have the same oil pan; so this pan is in no short supply) so i would just get the baffle plate from that model year too, and all seems it should slap on. i was in agony over fitment for several days; but this solves those issues for my project. this is my first turbo, and i love you omg Link to comment Share on other sites More sharing options...
