AustinHealey Posted December 30, 2019 Share Posted December 30, 2019 (edited) I was removing the steering rack on my 1995 Legacy wagon (a fun job, to be sure), and a hollow pin came out with it (see photo). I think it's likely that the pin didn't come from the rack (which generally are designed so pins don't fall out randomly), but had fallen on top of it -- months or years ago. So my question: Any guesses what it is? The inner diameter is approx 1/8," and the pin is apparently designed to be compressed by whatever goes around it. Only other job I've done recently was to replace the starter about a month ago, which has been working normally. All guesses and idle speculation welcomed! Edited December 30, 2019 by AustinHealey Link to comment Share on other sites More sharing options...
Thor294 Posted December 30, 2019 Share Posted December 30, 2019 Shifter bushing pin I believe Link to comment Share on other sites More sharing options...
donguaren Posted December 30, 2019 Share Posted December 30, 2019 It´s from the inner CV joint (diff side) it holds the CV axle from sliding out. Link to comment Share on other sites More sharing options...
Brighton96 Posted December 30, 2019 Share Posted December 30, 2019 I bet someone was really mad when they lost that haha. It can be either the CV axle one (on the trans side) or the shifter linkage. I would guess CV since that's a pretty normal job to do during the life of the car. Just check the holes on the CV axles to make sure a pin is already in there. Otherwise just hold onto it, those are pain to find replacements for. Link to comment Share on other sites More sharing options...
doublechaz Posted January 1, 2020 Share Posted January 1, 2020 I know for sure the way you get the one out of the axle inner CV it is likely to shoot out and then fall on top of the rack or cross member. Link to comment Share on other sites More sharing options...
ehsnils Posted January 1, 2020 Share Posted January 1, 2020 Those pins are pretty much standard spring pins. The length of the pin isn't a major concern, if it's too long just grind it down. If you need them you might find them here: http://nfgab.se/en/fasteners/9_pins-and-lock-rings/900_spring-roll-pin/1902_slotted-spring-pins-iso-8752/ Link to comment Share on other sites More sharing options...
