RikGT Posted November 8, 2019 Share Posted November 8, 2019 Hello all, I have the ability to get the AVO chargepipes for the 5thgen GT’s. They are available in red,Black,and blue. The price would be $245+shipping and PayPal fees. These were normally $328 plus shipping (depending where purchased some larger companies offered free shipping, I can’t) Yes, they are brand new from AVO. If you would like to purchase one please let me know as I will need to order a minimum of 10units. Thank you. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
dudemonster Posted November 8, 2019 Share Posted November 8, 2019 Thanks RikGT. I found an archived post by Elesedil a few years back in which they passed on a tech’s comment about fitment of the AVO charge pipe. Do you or does anyone here have any views on whether this one would rub/wear on other components due to shape/fit? I’d be quite interested if it’s not going to be problematic down the road. Link to comment Share on other sites More sharing options...
Scubaboo Posted November 9, 2019 Share Posted November 9, 2019 A member posted his install comments in this thread - https://legacygt.com/forums/showthread.php/avo-intercooler-hose-250070.html?t=250070&styleid=27 Fahr_side mentioned that he trusts the OE pipe to about 20psi but he said to remove the slip on connector couplings (?), have not dived in there to see what he meant by that. But with dgoodhue posting his blown pipe recently, I'm looking at options as well. Link to comment Share on other sites More sharing options...
dudemonster Posted November 9, 2019 Share Posted November 9, 2019 I think by slip-on connectors he may have been referring to the same prob I recently had with my pipe - wasn’t a pipe problem per se, but a degradation of the factory install helpers on either end, which just need to be removed after they get weakened and create leaks. Thanks for finding that other thread. The proximity to the fan shroud might be the issue, but probably not a biggie. Can fashion some chafing gear if that starts happening. Link to comment Share on other sites More sharing options...
RikGT Posted November 9, 2019 Author Share Posted November 9, 2019 Thanks RikGT. I found an archived post by Elesedil a few years back in which they passed on a tech’s comment about fitment of the AVO charge pipe. Do you or does anyone here have any views on whether this one would rub/wear on other components due to shape/fit? I’d be quite interested if it’s not going to be problematic down the road. I have the AVO CP and I personally recommend running a slim fan but you can run it with the OEM fan but need to trim down the bolt ends that stick out or they will press on the CP. I had it with the trimmed OEM fan for about 3-4 months but I decided to go with a slim fan just to have extra room. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Scubaboo Posted November 9, 2019 Share Posted November 9, 2019 NP dudemonster. RikGT, thanks for the additional insight. How will this work for people with upgraded thicker rads? I have a slightly thicker than stock aluminum rad (16mm vs 12mm stock). Some people have even thicker STI aluminum rads too. Link to comment Share on other sites More sharing options...
Aphex28 Posted November 9, 2019 Share Posted November 9, 2019 https://legacygt.com/forums/showpost.php?p=5926427&postcount=9 Link to comment Share on other sites More sharing options...
RikGT Posted November 9, 2019 Author Share Posted November 9, 2019 NP dudemonster. RikGT, thanks for the additional insight. How will this work for people with upgraded thicker rads? I have a slightly thicker than stock aluminum rad (16mm vs 12mm stock). Some people have even thicker STI aluminum rads too. I run a thicker Koyorad for an STi and I have a slim fan. If you’re increasing the width of the radiator then you will need a slimfan. These are designed with the OEM radiator not a thicker aftermarket one Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
RikGT Posted November 9, 2019 Author Share Posted November 9, 2019 https://legacygt.com/forums/showpost.php?p=5926427&postcount=9 That is obviously posted by someone who is touchy and wants everything to be perfect out the box. Sometimes you have to tweak a bit and by no means is the fitment “terrible” lol. I doubt the company would have made them and sold that many all over the world if they sucked so much. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Aphex28 Posted November 9, 2019 Share Posted November 9, 2019 I'd definitely be interested in modifying the process west piece to fit vs the AVO, but with a discount like this its definitely intriguing. Link to comment Share on other sites More sharing options...
mcg_ Posted November 11, 2019 Share Posted November 11, 2019 Also, FWIW, the fitment of the AVO chargepipe is terrible. In hindsight, I wish I would have kept the OEM and simply cut off the intercooler-connection end and bridge this area with a 6-inch silicone coupler. Instead, I have wrestled with the AVO-chargepipe half dozen times to get it to somewhat align with the turbo outlet without jacking-up the BPV connection. In fact, I have swapped the connection from the inlet pipe to BPV with a bent silicone coupler to relieve the mess, but it is still a frigg'n mess that is all caused by the AVO chargepipe. Link to comment Share on other sites More sharing options...
RikGT Posted November 12, 2019 Author Share Posted November 12, 2019 You might need help installing it correctly because I don’t have any of the issues you say you have and neither do a few other 5th gens with the AVO CP. I’m not really sure why you’re having this problem. I’ve emailed my rep at AVO about it and he is looking into it but said he’s never seen those issues either. Can you post some pics so I can show him? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
dgoodhue Posted November 12, 2019 Share Posted November 12, 2019 I already change my stock charge pipe due to it splitting so I don't need another one. I couldn't find the AVO CP so I assume it was discontinued. There are not really aren't any other bolt in options for 5th Gen GT CP. Link to comment Share on other sites More sharing options...
Scubaboo Posted November 12, 2019 Share Posted November 12, 2019 I already change my stock charge pipe due to it splitting so I don't need another one. I couldn't find the AVO CP so I assume it was discontinued. There are not really aren't any other bolt in options for 5th Gen GT CP. What did you end up going with? Link to comment Share on other sites More sharing options...
dgoodhue Posted November 13, 2019 Share Posted November 13, 2019 What did you end up going with? I bought GTEASER's RacerX charge pipe. Link to comment Share on other sites More sharing options...
Scubaboo Posted November 13, 2019 Share Posted November 13, 2019 I bought GTEASER's RacerX charge pipe. Link to comment Share on other sites More sharing options...
RikGT Posted November 18, 2019 Author Share Posted November 18, 2019 I already change my stock charge pipe due to it splitting so I don't need another one. I couldn't find the AVO CP so I assume it was discontinued. There are not really aren't any other bolt in options for 5th Gen GT CP. HKS makes one as well. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
RikGT Posted November 18, 2019 Author Share Posted November 18, 2019 If anyone is interested let me know your zip codes and I can get you the shipping cost Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Zee199969 Posted November 18, 2019 Share Posted November 18, 2019 HKS makes one as well. Sent from my iPhone using Tapatalk The HKS one won't work with USDM cars https://legacygt.com/forums/showpost.php?p=5381482&postcount=27 My "Build" Link to comment Share on other sites More sharing options...
ibr_adam09 Posted November 18, 2019 Share Posted November 18, 2019 Why doesn't the Grimm-speed fit again? I remember reading something about the Wrx turbo outlet positioned/ angled differently? It looks to be be manageable with a small modification, no? Link to comment Share on other sites More sharing options...
Sarang Posted November 18, 2019 Share Posted November 18, 2019 Maybe. You'd be taking a risk to find out. Link to comment Share on other sites More sharing options...
Justen1987 Posted November 18, 2019 Share Posted November 18, 2019 interested. I sent pm but didn't hear back zip is 46554 Link to comment Share on other sites More sharing options...
FLlegacy Posted November 19, 2019 Share Posted November 19, 2019 Why doesn't the Grimm-speed fit again? I remember reading something about the Wrx turbo outlet positioned/ angled differently? It looks to be be manageable with a small modification, no? The wrx outlet is angled a lot more but it may be more than that, I thought someone here had comparison pictures but I could be wrong. Link to comment Share on other sites More sharing options...
Sarang Posted November 19, 2019 Share Posted November 19, 2019 Also the by pass valve is 25mm vs the LGT 34mm Link to comment Share on other sites More sharing options...
RikGT Posted November 20, 2019 Author Share Posted November 20, 2019 Also the by pass valve is 25mm vs the LGT 34mm That is easily fixable. I run a boomba BPV for the 15+WRX and have a pic somewhere of the hose you use to act as an adapter the way other companies do. Once I find pic with the part number I will post. It’s available at any parts store. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
