ecuflash
Im having trouble flashing from a at to mt rom. can any1 help explain what this error log? after like 5 seconds it says error see log for details
[06:08:24.953] Version 1.29.906
[06:08:24.953] 8 memory models read.
[06:08:41.593] 339 ROM metadata models read.
[06:08:41.593] checksum module "subarudbw" loaded.
[06:08:41.593] flashing tool "wrx02" loaded.
[06:08:41.593] flashing tool "wrx04" loaded.
[06:08:41.593] flashing tool "sti04" loaded.
[06:08:41.593] flashing tool "sti05" loaded.
[06:08:41.593] flashing tool "mitsukernel" loaded.
[06:08:41.593] flashing tool "mitsukernelocp" loaded.
[06:08:41.593] flashing tool "mitsubootloader" loaded.
[06:08:53.031] 1048576 byte image read.
[06:09:03.859] ssm2_init
[06:09:04.015] ECU ID is 2F 12 50 52 06
[06:09:04.015] ssm2_cmd_0x81
[06:09:04.062] ssm2_cmd_0x83
[06:09:04.109] denso challenge-response
[06:09:04.171] challenge is 56 68 EF A0
[06:09:04.171] response is 00 75 23 77
[06:09:04.218] ssm2_cmd_0x10
[06:09:04.578] validating denso kernel ram area addr: FFFF3000 len: 0C28
[06:09:04.593] writing denso kernel area addr: FFFF3000 len: 0C28
[06:09:04.796] writing denso flash block addr: FFFF3000 len: 0080
[06:09:05.109] writing denso flash block addr: FFFF3080 len: 0080
[06:09:05.406] writing denso flash block addr: FFFF3100 len: 0080
[06:09:05.718] writing denso flash block addr: FFFF3180 len: 0080
[06:09:06.015] writing denso flash block addr: FFFF3200 len: 0080
[06:09:06.312] writing denso flash block addr: FFFF3280 len: 0080
[06:09:06.625] writing denso flash block addr: FFFF3300 len: 0080
[06:09:06.921] writing denso flash block addr: FFFF3380 len: 0080
[06:09:07.234] writing denso flash block addr: FFFF3400 len: 0080
[06:09:07.531] writing denso flash block addr: FFFF3480 len: 0080
[06:09:07.843] writing denso flash block addr: FFFF3500 len: 0080
[06:09:08.140] writing denso flash block addr: FFFF3580 len: 0080
[06:09:08.453] writing denso flash block addr: FFFF3600 len: 0080
[06:09:08.750] writing denso flash block addr: FFFF3680 len: 0080
[06:09:09.046] writing denso flash block addr: FFFF3700 len: 0080
[06:09:09.359] writing denso flash block addr: FFFF3780 len: 0080
[06:09:09.656] writing denso flash block addr: FFFF3800 len: 0080
[06:09:09.968] writing denso flash block addr: FFFF3880 len: 0080
[06:09:26.578] ssm2_init
[06:09:26.796] ssm2_init
[06:09:27.015] ssm2_init
[06:09:27.234] ssm2_init
[06:09:27.468] ssm2_init
[06:09:27.687] ssm2_init
[06:09:27.906] ssm2_init
[06:09:28.140] ssm2_init
[06:09:28.359] ssm2_init
[06:09:28.578] ssm2_init
[06:09:28.968] kernel get version
[06:09:29.484] validating denso kernel ram area addr: FFFF3000 len: 0008
[06:09:29.703] validating denso kernel ram area addr: FFFF3000 len: 0C28
[06:09:29.718] writing denso kernel area addr: FFFF3000 len: 0C28
[06:09:29.921] writing denso flash block addr: FFFF3000 len: 0080
[06:09:30.234] writing denso flash block addr: FFFF3080 len: 0080
[06:09:30.531] writing denso flash block addr: FFFF3100 len: 0080
[06:09:30.843] writing denso flash block addr: FFFF3180 len: 0080
[06:09:31.140] writing denso flash block addr: FFFF3200 len: 0080
[06:09:55.812] ssm2_init
[06:09:56.031] ssm2_init
[06:09:56.250] ssm2_init
[06:09:56.468] ssm2_init
[06:09:56.703] ssm2_init
[06:09:56.921] ssm2_init
[06:09:57.140] ssm2_init
[06:09:57.375] ssm2_init
[06:09:57.593] ssm2_init
[06:09:57.812] ssm2_init
[06:09:58.187] kernel get version
[06:09:58.718] validating denso kernel ram area addr: FFFF3000 len: 0008
[06:09:58.937] validating denso kernel ram area addr: FFFF3000 len: 0C28
[06:09:58.953] writing denso kernel area addr: FFFF3000 len: 0C28
[06:09:59.156] writing denso flash block addr: FFFF3000 len: 0080
[06:09:59.468] writing denso flash block addr: FFFF3080 len: 0080
[06:09:59.765] writing denso flash block addr: FFFF3100 len: 0080
[06:10:00.078] writing denso flash block addr: FFFF3180 len: 0080
[06:10:00.375] writing denso flash block addr: FFFF3200 len: 0080
We need some more info before we can begin to help.
What is the year/make/model of the car?
Which cable are you using to read / write to the ecu? (openport 2.0, tactrix brand 1.3 cable, generic Vagcom, ect) and if a generic cable, WHICH exact generic cable?
If the car is pre-2007, did you connect the green clips under the dash to put the car into reflash mode (for lack of official better terminology) before trying to read/write?
OK so it looks like your car originally has the rom A2WC510C and your trying to flash over it with something like A2WC522N, correct?
From my past experience, as long as you match the first 4 characters of the ECUID, the roms should be interchangeable.
did you setup your ecuflash correctly??
should it be loading all this other crap?
I thought we needed a specific library or folder for our cars?
Hey tech,
Those are all normal. Every time you load up ecuflash, those get loaded and display in the console. They are the default car read templates available from ecuflash.
Sent from my SM-N960U using Tapatalk
I haven't flashed in a while, but I do remember all the cheap vag coms would stop working eventually and would only let me read and not write, it became a pita so I just went the tactrix openport and had no problems since.
