KylerBelluz Posted September 18, 2019 Share Posted September 18, 2019 So I got my new tires mounted today on my 18x9 wheels which are 245/45/18, and the front is in contact with the strut spring and so is the rear but not as bad. I’m just wondering what size of spacers I should run. I’m thinking 10mm all around just to be safe but would like a second opinion. The car is an 05 Legacy GT. Thanks. Link to comment Share on other sites More sharing options...
whitetiger Posted September 18, 2019 Share Posted September 18, 2019 what is the offset of the wheels? Link to comment Share on other sites More sharing options...
KylerBelluz Posted September 19, 2019 Author Share Posted September 19, 2019 what is the offset of the wheels? Not too sure, got the wheels second hand and was never told the exact specs Link to comment Share on other sites More sharing options...
awfulwaffle Posted September 19, 2019 Share Posted September 19, 2019 Should be cast/inscribed somewhere on the wheel. Usually the backside of the spoke or center hub Link to comment Share on other sites More sharing options...
gkinslow Posted September 19, 2019 Share Posted September 19, 2019 Not too sure, got the wheels second hand and was never told the exact specs Can't expect accurate answers without all the requisite information. https://www.willtheyfit.com/ Link to comment Share on other sites More sharing options...
whitetiger Posted September 19, 2019 Share Posted September 19, 2019 Not too sure, got the wheels second hand and was never told the exact specs you need to find out. i could say 10mm spacers would do it for you if you have a +40 to +48 wheel, but an alignment change could also do it. if you are running coilovers, one trick would be to max positive on the camber bolts while using the camber plates to get back to negative. in the rear. a combination of camber arms and the top camber bolt can space out the wheel from the car more to give you clearance. Link to comment Share on other sites More sharing options...
grovlet Posted September 19, 2019 Share Posted September 19, 2019 Hmm 245/45/18 - That sounds like the wrong tire size for the LGT.... Based on the Wheel / Tire Faq - you really are looking for a 245/35/18 tire... Also as noted the Offset is also critical to the mix here as well - but you'll see in the Faq recommendations for the best fitting offset options. LGT Wheel / Tire Faq Link to comment Share on other sites More sharing options...
whitetiger Posted September 19, 2019 Share Posted September 19, 2019 ^this too. 245/35/18 is the correct tire size Link to comment Share on other sites More sharing options...
Holla Posted September 19, 2019 Share Posted September 19, 2019 Even if you get this setup to fit without rubbing, it’s not going to look right on the stock suspension. Link to comment Share on other sites More sharing options...
Con.Harr91 Posted September 19, 2019 Share Posted September 19, 2019 You definitely have the wrong tires for your car, and from what it sounds like the wrong wheels too. '03 Forester X 5mt - Engine Seized at 262k miles. '05 LGT Wagon 6mt -MotoIQ.com Project Vehicle '13 VW Touareg TDI - Daily Torque Monster. Link to comment Share on other sites More sharing options...
