Beamercub Posted August 27, 2019 Share Posted August 27, 2019 Belt squeal after car has been sitting or on humid days. Happens when starting car, immediately stop if I turn off A/C. Sometimes I turn a/c off and back on to make noise go away. Otherwise would squeal for 30-45 seconds.. Belt is newer replaced about 6 months ago.. Indication of belt being too tight or loose? The 3.6R is manually adjusted, doesn't have the auto belt tensioner. Any insight? -cheers Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted August 27, 2019 Share Posted August 27, 2019 miles on car? I would replace the belt and then properly tension the new one. Link to comment Share on other sites More sharing options...
SubieN8 Posted August 27, 2019 Share Posted August 27, 2019 Unsure, but I thought there was a TSB years ago, for this. Link to comment Share on other sites More sharing options...
hkshooter Posted August 27, 2019 Share Posted August 27, 2019 Who replaced it? Squeal is usually too lose, either due to age, wear. If it's new it's too loose. Tighten it up a little. Sent from my SM-G950U using Tapatalk Link to comment Share on other sites More sharing options...
Imprzme Posted August 27, 2019 Share Posted August 27, 2019 Is it belt squeal or are the compressor/compressor clutch bearings on the way out? Link to comment Share on other sites More sharing options...
KSKarl Posted August 28, 2019 Share Posted August 28, 2019 What hk said. OP said the belt was replaced recently, probably got a little looser as it took its initial set. They usually need a second adjustment after running a little while. Link to comment Share on other sites More sharing options...
Beamercub Posted August 28, 2019 Author Share Posted August 28, 2019 miles on car? I would replace the belt and then properly tension the new one. I replaced the belt in April/2019. The squal happens only on humid days.. I guess i could try tightening it or loosening it.. Link to comment Share on other sites More sharing options...
Beamercub Posted August 28, 2019 Author Share Posted August 28, 2019 Unsure, but I thought there was a TSB years ago, for this. Funny. I mentioned to TSB before I had replaced the belt. I got the deer in headlights look. Rather than belittle them or waste my time, I bought a belt from the parts department and did it myself. And yes, the belt material was drastically different in construction compared to the original one on the car.. Not different from wear or age, the actual materail was different. Link to comment Share on other sites More sharing options...
Beamercub Posted August 28, 2019 Author Share Posted August 28, 2019 Is it belt squeal or are the compressor/compressor clutch bearings on the way out? The compressor was replaced 6/2017. And the belt squal while compressor was running stayed almost the same after replacement. You would think they would have replaced the belt at the same time, but nope. I waited about 2 years before replacing the belt on my own.. Link to comment Share on other sites More sharing options...
Beamercub Posted August 28, 2019 Author Share Posted August 28, 2019 What hk said. OP said the belt was replaced recently, probably got a little looser as it took its initial set. They usually need a second adjustment after running a little while. I will tighten it a bit today. Link to comment Share on other sites More sharing options...
apexi Posted August 29, 2019 Share Posted August 29, 2019 In your older thread I didn't see any mention of belt squeal, just noise from a low charge or possibly a bearing. In late 2016 or early 2017, why would they change the belt on a car that was merely 2-3 years old, and had less than 30k? Yeah the belts may not be expensive, but dealers can't just replace these "cheap" parts on every vehicle that comes in. Different belt material really means nothing, probably just made by a different manufacturer, doesn't suggest a problem with the oem belt that they changed. Link to comment Share on other sites More sharing options...
