A_A_ron Posted August 12, 2019 Share Posted August 12, 2019 I am talking the advice of the LGT performance mods thread and replacing some turbo lines that have been known to rust away. Parts referenced in this post. https://legacygt.com/forums/showpost.php?p=5241759&postcount=19364 Anyone who has done this, have you any advice for how to go about replacing these lines or tips on making it easier? Did you have to pull the turbo? Build Thread Link to comment Share on other sites More sharing options...
coco26 Posted August 13, 2019 Share Posted August 13, 2019 Just did this a few weeks ago with the braided lines instead. I think going with the OEM parts is the right move. I'd probably suggest painting them too for future rust prevention. No need to drop the turbo. The upper heat shield can stay, but I can't remember if there was a shield on the lower side that had to be removed to get at the banjos. That part should be pretty obvious if there is. The banjos are very close to the front motor mount. Its doable as is, but it may make your life easier if you get that mount out of the way. I did the swap with the engine out of the car, then tightened them in the car with the mount in place. The best I could do was from underneath, about 1/12 of a turn with a standard wrench at a time. You should be able to pinch off the rubber coolant lines with vise grips well enough to prevent a major mess, but I'd have some spare coolant ready to top off. Link to comment Share on other sites More sharing options...
Falcor Posted August 13, 2019 Share Posted August 13, 2019 I'll have to check mine out as well. Esp since the 90k maintenance is coming up in 1k. The coolant will be changed anyway. Link to comment Share on other sites More sharing options...
coco26 Posted August 13, 2019 Share Posted August 13, 2019 My car was at 78k and 8 New York winters, and the tubes were still structurally sound, but had definitely lost a few layers worth of rust. I would've given it another 2-3 years before pinholes started. Link to comment Share on other sites More sharing options...
dgoodhue Posted August 14, 2019 Share Posted August 14, 2019 I didn't replace mine since my car is pretty rust free, but it seem pretty easy to replace with the timing belt/water pump maintenance. Link to comment Share on other sites More sharing options...
Libacy GT Posted August 15, 2019 Share Posted August 15, 2019 Can you please list all the replacement parts that you ordered? Sent from my HTC_M10h using Tapatalk Link to comment Share on other sites More sharing options...
A_A_ron Posted August 16, 2019 Author Share Posted August 16, 2019 I'll try to find the invoice. That will be easiest. Build Thread Link to comment Share on other sites More sharing options...
Libacy GT Posted August 19, 2019 Share Posted August 19, 2019 I'll try to find the invoice. That will be easiest.Howd u go with the parts list? Sent from my HTC_M10h using Tapatalk Link to comment Share on other sites More sharing options...
A_A_ron Posted August 19, 2019 Author Share Posted August 19, 2019 Did not find it yet. Bust weekend. I'll check tonight. Build Thread Link to comment Share on other sites More sharing options...
Libacy GT Posted August 19, 2019 Share Posted August 19, 2019 Did not find it yet. Bust weekend. I'll check tonight.No problem mate. Thanks for your help Sent from my HTC_M10h using Tapatalk Link to comment Share on other sites More sharing options...
Brett_dub Posted August 26, 2019 Share Posted August 26, 2019 Code: 14430AA220 PIPE COMPLETE-TURBO,NO.2 1 14472AA250 HOSE ASSEMBLY-WATER 1 14480AA010 CONNECTOR-TURBOCHARGER PIPE 1 15194AA100 SCREW-UNION 2 803912040 GASKET 4 803912130 GASKET-12.5X17X2 1 Just in case, that last figure is the quantity needed. I did mine when doing the timing belt a couple years ago. I had some heat shields that rusted away, but i did change it with the motor mount attached. Not sure if the missing heat shield made a difference or not, but if I had to guess I’d say they are pretty easily accessible. I did also have the radiator and fans out. Good luck 1 Link to comment Share on other sites More sharing options...
