Cracks on the hot side. IHI VF40
My turbocharger went out some time ago and I just got serious about fixing it. So after a week of penetrating oil propane torches and hammering I finally got my turbo separated and I found some problems. I was going to get a replacement cartridge but with the cracks on the waste gate I guess a whole new unit is in order. Any thoughts?
Edited by crazyche
pics
We've have had cast iron welded on other turbo in the past. Others have had cracks and just keep running them.
But on a vf40...not sure its worth it.
why is that hot section so moist ? is that oil pr penetrating fluid ?
Engine Build - Click Here
Those cracks affect nothing. They're inherent in the design once the turbo has been run for any length of time. The VF39/43/48/52 also all develop cracks, much worse than those internal cracks on the VF40/46 housings, and they affect nothing.
It's penetrating oil. The turbine shaft split but nothing grenaded it just stopped. I want to go with the replacement cartridge but when I saw the crack I thought I was out of luck.
Sent from my moto e5 plus using Tapatalk
I highly recommend you send it off to JmP, in the above post, he is the "go to guy" for having your turbo rebuilt right the first time.
Can a mod please merge the three threads created about this into one?
OP, as stated the crack is fine; It is really challenging to find a used VF turbo without the wastegate crack. In the future search first and please only start one thread about your issue.
  • 1 year later...
I had a sound like a taser gun ticking loud and sharply at above 4k rpm and no boost. Chased it down to find bad cracks in my wastegate segment of the hot side . Total cost was $80 for a new genuine IHI turbine half plus time
