06imprezawrxsti Posted May 10, 2020 Share Posted May 10, 2020 Anyone whom can assist me perhaps remotely in getting this done? Having issues/lack of understanding on running the read and write scripts. I think I have gotten everything else set up correctly on Mac, gave up on Windows after couple days of attempts. Any help would be extremely appreciated. Link to comment Share on other sites More sharing options...
Infosecdad Posted May 10, 2020 Author Share Posted May 10, 2020 Where are you at with it? What’s your setup and are you seeing error messages? Link to comment Share on other sites More sharing options...
06imprezawrxsti Posted May 10, 2020 Share Posted May 10, 2020 Currently seem to have board wired up properly and Python3 working on Mac OSX, as per the following instructions https://learn.adafruit.com/circuitpython-on-any-computer-with-ft232h/mac-osx Not sure how to run the "read" "write" scripts though to pull any data off the chip (I believe that seems to be the next step where I should be going). I ran into issues with these instructions https://learn.adafruit.com/adafruit-ft232h-breakout/mac-osx-setup for Mac OSX and could not get the software running. For the Windows setup I got stuck in adding the Adafruit Python GPIO Library. Thus my reasoning for finally following the instructions mentioned for Mac OSX. Also bear with me I have little to no experience in the computer software aspect as far as writing programs and such. Mechanically I do anything from engine/transmission rebuilding, wiring schematic diagnostics, automotive software programming, etc. Link to comment Share on other sites More sharing options...
Infosecdad Posted May 10, 2020 Author Share Posted May 10, 2020 If you have downloaded the ft232h project from GitHub with the eeprom-read.py and eeprom-write.py files, you can call them with python3 eeprom-read.py or python3 eeprom-write.py commands. I haven't tried them with python3, I had python 2.7 at the time, so I'm not 100% sure they will work with python3. It'll likely be dependent on if there are python3 versions of the libraries needed from the import statements. You might also have python 2.7 on your Mac as well, depending on your version. You can test this by typing "python" in a terminal window. You might see a message like this: WARNING: Python 2.7 is not recommended. This version is included in macOS for compatibility with legacy software. Future versions of macOS will not include Python 2.7. Instead, it is recommended that you transition to using 'python3' from within Terminal. Python 2.7.16 (default, Feb 29 2020, 01:55:37) [GCC 4.2.1 Compatible Apple LLVM 11.0.3 (clang-1103.0.29.20) (-macos10.15-objc- on darwin Type "help", "copyright", "credits" or "license" for more information. >>> type "quit()" to close the python interpreter. If that worked, then you can use python 2.7 by running: python eeprom-read.py or python eeprom-write.py from the directory they are located in from the terminal. Let me know if that helps or not. Link to comment Share on other sites More sharing options...
awfulwaffle Posted May 11, 2020 Share Posted May 11, 2020 I had issues with Python 3 and ft232h. I chose the lazy path and reinstalled 2.7. Link to comment Share on other sites More sharing options...
Infosecdad Posted May 11, 2020 Author Share Posted May 11, 2020 You can run them in parallel, that's why they have "python" and "python3". Just managing their respective environments can be a real pain... Link to comment Share on other sites More sharing options...
06imprezawrxsti Posted May 12, 2020 Share Posted May 12, 2020 (edited) Ok, so I've ran python 2.7 (already installed as mentioned, but I never installed any drivers or libraries such as I did for python3. That perhaps might be another issue all together?) and python3 on terminal followed by dragging the eeprom-read.py which is located on the desktop with the following result after pressing enter (return) (girlfriend's laptop so disregard user name haha) File "<stdin>", line 1 /Users/mariaestherjoaquintaveras/Desktop/eeprom-read.py ^ SyntaxError: invalid syntax Also I am doing this with just the ft232h connected via usb (test clip is not connected to ECU at the moment, if I'm correct this shouldn't be an issue currently as I'm just tying to get everything running properly before hooking up the test clip) Edited May 12, 2020 by 06imprezawrxsti Link to comment Share on other sites More sharing options...
Infosecdad Posted May 12, 2020 Author Share Posted May 12, 2020 On the Mac you need to open the Terminal. You can pull up spotlight with command+space and type "terminal" Once terminal is open cd ~/Desktop python eeprom-read.py You should see some note from it attempting to execute the python file. Link to comment Share on other sites More sharing options...
06imprezawrxsti Posted May 12, 2020 Share Posted May 12, 2020 That was helpful I see how it changed directory to look in the desktop, was not aware how to do that. Following were the results Traceback (most recent call last): File "eeprom-read.py", line 1, in <module> import ftdi1, os, sys, time, logging ImportError: No module named ftdi1 marias-Air:desktop mariaestherjoaquintaveras$ going to try and follow these instructions for python2.7 https://learn.adafruit.com/adafruit-ft232h-breakout/mac-osx-setup maybe I'm missing something? Since I followed the python3 directions. Link to comment Share on other sites More sharing options...
Infosecdad Posted May 12, 2020 Author Share Posted May 12, 2020 That’s progress. That says that it can’t find the ftdi1 module, so you should go back to that section of the instructions and try to get that module installed. Link to comment Share on other sites More sharing options...
06imprezawrxsti Posted May 14, 2020 Share Posted May 14, 2020 Kept getting an error. Gave up on Mac OSX this time around, went back on my Windows this afternoon and started from scratch carefully following each step. GOT IT TO WORK!! Vehicle is now running on the donor ECM, going to be testing it the next couple days. Thanks for all the help. Link to comment Share on other sites More sharing options...
jdmchico Posted May 18, 2020 Share Posted May 18, 2020 I read Ryan's thread, I ended up getting that adafruit and never used it. The raspberry pi 4 turned out to be the best and error free method. In my case I wanted to change clusters as I had a pre-facelift and I been converting my car over to a facelift version. My car is a 2006 JDM Spec B. I was able to source the tuned by Sti cluster and finally figure out how to convert my immobilizer code to the new cluster. Link to comment Share on other sites More sharing options...
SAABaruu Posted May 23, 2020 Share Posted May 23, 2020 In my case i am replacing my ecu with a JDM one in order to properly run my new JDM engine. It was my understanding that I could hire a car locksmith to program my key to the new ECU? Why not have that done to the replacement ECU? This would be pre facelift cars only from my understanding Link to comment Share on other sites More sharing options...
jdmchico Posted May 23, 2020 Share Posted May 23, 2020 (edited) I have a spare ECU that I sourced (tuned by STI); I just basically copied my current ECU's eeprom using a raspberry pi 4 and 8 pin chip clip. and it worked without issue. No locksmith needed. Edited May 23, 2020 by jdmchico Link to comment Share on other sites More sharing options...
Infosecdad Posted May 23, 2020 Author Share Posted May 23, 2020 In my case i am replacing my ecu with a JDM one in order to properly run my new JDM engine. It was my understanding that I could hire a car locksmith to program my key to the new ECU? Why not have that done to the replacement ECU? This would be pre facelift cars only from my understanding The ECU has to match two other components in the system, you can't just program the key to the ECU; you need to update the ECU to match the rest of the car. From my understanding there are three ways to do that: 1. Take it to a dealer with the system and willingness to actually reprogram a replacement ECU. Not all will do it. 2. Physically move the eeprom chip from your old ECU to the replacement. If you are good with soldering this is fairly easy, but you risk bricking both. 3. The method in this thread to clone the "code" (your VIN and whatnot in a specific format) to the replacement ECU. Link to comment Share on other sites More sharing options...
Gogetter Posted July 24, 2020 Share Posted July 24, 2020 I have an ECU that looks slightly different. Can anyone assist in identifying the correct chip? Link to comment Share on other sites More sharing options...
Infosecdad Posted July 24, 2020 Author Share Posted July 24, 2020 That's a little blurry, but I don't see it on this side; can you upload a picture of the other side as well? Link to comment Share on other sites More sharing options...
awfulwaffle Posted July 24, 2020 Share Posted July 24, 2020 Hard to see the component labels in that pic. Every board I've handled (which is 4 so far) had the immobilizer EEPROM tagged IC405. Link to comment Share on other sites More sharing options...
Gogetter Posted July 24, 2020 Share Posted July 24, 2020 Thank you. Link to comment Share on other sites More sharing options...
Gogetter Posted July 24, 2020 Share Posted July 24, 2020 (edited) More pics This ECU is from a 2009 Outback Edited July 24, 2020 by Gogetter Link to comment Share on other sites More sharing options...
Gogetter Posted July 24, 2020 Share Posted July 24, 2020 (edited) Hard to see the component labels in that pic. Every board I've handled (which is 4 so far) had the immobilizer EEPROM tagged IC405. I don't see any 8 leg marked IC405 on this board the chip i think it is compairing this video is IC402 It looks a lot like the board from this video Edited July 24, 2020 by Gogetter Link to comment Share on other sites More sharing options...
Infosecdad Posted July 24, 2020 Author Share Posted July 24, 2020 I believe it would be the IC402. Someone from the romraider forum indicated the same. http://romraider.com/forum/viewtopic.php?f=7&t=11379 Link to comment Share on other sites More sharing options...
Gogetter Posted July 24, 2020 Share Posted July 24, 2020 Thank you. I've read and verified successfully a couple times. Can you check this dump? I don't see a vin anywhere but the read wasn't all FFFF http://www.mediafire.com/file/00oc1fbdqs1jx63/subecu2.bin/file Link to comment Share on other sites More sharing options...
EatingInternet Posted July 28, 2020 Share Posted July 28, 2020 Can this be used to program a new key to the same ecu? Or only for a key that was already programmed? From what I understand you're copying a rom over but not editing it. Link to comment Share on other sites More sharing options...
d22597 Posted July 28, 2020 Share Posted July 28, 2020 Thank you. I've read and verified successfully a couple times. Can you check this dump? I don't see a vin anywhere but the read wasn't all FFFF http://www.mediafire.com/file/00oc1fbdqs1jx63/subecu2.bin/file I’m having a similar issue with my 09. It appears my ecu has a different model eeprom with a different storage capacity. I’m still working through the code and confirming, but I’m guessing the code needs to assign a different address sequence for the different chip. Can you get a clear pic of the eeprom model? Mine is an S93C86. The code was written for a BR93L56. The 56 is a 2Kbit capacity and the 86 is a 16Kbit capacity. Link to comment Share on other sites More sharing options...
