2010 2.5GT Injector Size???
Posted
Guys,
Does anyone knows the size of the injectors on the 2.5 GT Legacy. I've also attached a picture of my current / stock injectors....however, i can't find out what's it size / cc.
Regards,
Brian
Posted
Guys,
Regards,
Brian
Whatever those injectors are, they are not the stock ones.
From my gathering and research, those seem to be the stock cc flow, but a ebay/amazon brand. Non denso oem brand
I’m guessing your having issues with them?
Posted
Thanks for the response. But actually it is the Original Denso Injectors. It's working fine...however, I don't know the size / cc flow and as such I would like to know for future upgrades if need be. It is marked Denso on the other side.
Thanks for the reply bro.
Posted
Here it is Denso...but i do agree, on Amazon you're not seeing the Denso Green Injector??? hmmm
Posted
If your Gt is not tuned and completely stock.
You can most certainly know that those are stock size CC injectors then.
Anything else will result in a completely poor running car.
You have the turbo model or NA?
Posted
It is a Turbo vehicle (2.5GT)...and yes i do believe that the engine is stock. So with that in mind, I would tend to lead on the side of the Injectors being 550's. But, I just wish that i had some sort of conformation on that...rather than guesstimating.
Regards,
Brian
Posted
Stock car.. stock injectors.
No guessing here.
Get some stock oem denso ones and see if they’ll run good. That’ll answer your question.
Or find someone locally and take a peak at your map and see if it’s been opensourced.
Posted
No guessing here.
Thanks....Will keep you posted bro.
regards,
Brian
Posted
These are stock injectors (same as the ones that came on my 2010 AUDM 5eat GT).
They are 525cc (you can actually open your stock rom in ECUflash or romraider and read the stock injectors scaler value to see this).
