Ares3985 Posted June 16, 2019 Share Posted June 16, 2019 So I see conflicted answers on how many banjo bolts there are and where they are. I have an 08 LGT. So far I found one under the intake. I also found one next to my oil fill. Neither had a filter in them and it wasn’t still in the hole. Is there a third one at the turbo or is this it? I removed that bracket and looked for one. I found a bolt with an orange line it on the back of the motor. I can’t even get on it so I gave up. Not even sure if that’s what it is. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Ares3985 Posted June 16, 2019 Author Share Posted June 16, 2019 Banjo 1 under Intake Banjo 2 next to oil fill Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
rhino6303 Posted June 16, 2019 Share Posted June 16, 2019 Those are banjo bolts, yes, but not the ones that have filters. Those are banjo bolts for the avcs solenoids. On your 08, the banjo location for turbo side is under the turbo inlet. The second is behind the timing cover on the front left of the engine (near a/c compressor). I didn't think the 08 vehicles have filters in them. Link to comment Share on other sites More sharing options...
Ares3985 Posted June 16, 2019 Author Share Posted June 16, 2019 Those are banjo bolts, yes, but not the ones that have filters. Those are banjo bolts for the avcs solenoids. On your 08, the banjo location for turbo side is under the turbo inlet. The second is behind the timing cover on the front left of the engine (near a/c compressor). I didn't think the 08 vehicles have filters in them. I’m not sure if they do. It seems like a pain to get to tho. Just found it. Which stinks cause I had the inlet off yesterday and it was the worst to get the new one in. I am throwing a p0011 code. So I checked the 2 i mentioned. Now I just have to get to the turbo one. But if it has no filter then there is no point. I also ordered a new ocv solenoid. Can’t get the old one out though as it hits the bracket. Not sure if I should keep digging in and remove the inlet again or just assume there is no filter Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
rhino6303 Posted June 16, 2019 Share Posted June 16, 2019 If the bolt head is flat, there is no filter. If the bolt head has a nipple, there is a filter. Link to comment Share on other sites More sharing options...
Ares3985 Posted June 16, 2019 Author Share Posted June 16, 2019 (edited) If the bolt head is flat, there is no filter. If the bolt head has a nipple, there is a filter. Damn it. It has the nipple. [ Edited June 16, 2019 by Ares3985 Link to comment Share on other sites More sharing options...
Max Capacity Posted June 17, 2019 Share Posted June 17, 2019 (edited) https://forums.nasioc.com/forums/showthread.php?t=2834394 That link used to be the picture of where the filters are for various years. The banjos your looking for have a raised portion on the top not a real nipple. there is a good thread on here about removing them with pictures, do a google search. FWIW, my 09 has both filters still installed. IMO 07-09's don't have the same issue with them as the 05-06's Edited June 17, 2019 by Max Capacity 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted June 17, 2019 Share Posted June 17, 2019 Try this, https://legacygt.com/forums/showthread.php/2-5gt-turbo-oil-supply-banjo-bolt-filter-removal-62371.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
whitexc Posted June 17, 2019 Share Posted June 17, 2019 My '09 had the one under the inlet/back of the head (turbo feed line) that I removed while the inlet was off and being replaced. I don't see any other way than to have the inlet removed to access that one. I have not touched any others on my car. It was dirty but did not appear to be clogged. Link to comment Share on other sites More sharing options...
jcaroth Posted June 17, 2019 Share Posted June 17, 2019 '08's do indeed have a filter on the banjo bolt under the turbo (this was the last major work I did on my car). Easiest way to get to it is by removing the inlet, as others have mentioned. Link to comment Share on other sites More sharing options...
JmP6889928 Posted June 17, 2019 Share Posted June 17, 2019 You can reach the back of the PS head to remove that banjo filter from underneath the car -not easily, but it can certainly be done. Link to comment Share on other sites More sharing options...
Ares3985 Posted June 18, 2019 Author Share Posted June 18, 2019 You can reach the back of the PS head to remove that banjo filter from underneath the car -not easily, but it can certainly be done. No way. It’s directly under the turbo inlet and vertical. I just did it. Had to take off the Intercooler, the inlet, and the small coolant tank. Was not fun. Took about 2.5 hours. I covered it in another post. Hopefully this solves my problem. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Darth SpecB Posted June 18, 2019 Share Posted June 18, 2019 Imo removing the turbo is much easier than the inlet. Plenty of access once that is out of the way. Sent from my SM-G950U using Tapatalk Link to comment Share on other sites More sharing options...
Ares3985 Posted June 18, 2019 Author Share Posted June 18, 2019 Imo removing the turbo is much easier than the inlet. Plenty of access once that is out of the way. Sent from my SM-G950U using Tapatalk Your right. Would have been probably. It intimidated me a little bit truth be told. I guess it shouldn’t though because I removed a lot the way I did it too Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
