Ares3985 Posted May 23, 2019 Share Posted May 23, 2019 I’m not sure what this filter is. Can anyone identify it? I want to replace it. Looks ratty Sits to the left of the alternator. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
utc_pyro Posted May 23, 2019 Share Posted May 23, 2019 It's for the MAP sensor. Keeps oil vapor for hurting it, and helps smooth the air pulses. Link to comment Share on other sites More sharing options...
apexi Posted May 24, 2019 Share Posted May 24, 2019 Interesting, I'm not 100% positive that this is it, but it looks like you have to get it with the hoses. https://parts.subaru.com/p/Subaru_2008_Legacy-25L-TURBO-5MT-4WD-GT-Limited-Sedan/HOSE-ASSEMBLY-VACUUM/49231576/22310AC270.html https://parts.subaru.com/a/Subaru_2008_Legacy-25L-TURBO-5MT-4WD-GT-Limited-Sedan/_54102_6026548/INTAKE-MANIFOLD-INTAKEMANIFOLD-SYSTEM--THROTTLE-07MY-/B13-050-21.html Link to comment Share on other sites More sharing options...
JmP6889928 Posted May 24, 2019 Share Posted May 24, 2019 Isn't that a diaphragm to smooth the pulses and not a filter? Link to comment Share on other sites More sharing options...
Max Capacity Posted May 24, 2019 Share Posted May 24, 2019 Mine looks like that too. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
utc_pyro Posted May 24, 2019 Share Posted May 24, 2019 Isn't that a diaphragm to smooth the pulses and not a filter? Nope, you can flow through it. There is a yellow/white foam inside. Link to comment Share on other sites More sharing options...
moral hazard Posted May 25, 2019 Share Posted May 25, 2019 Part number : 22663AA010 Link to comment Share on other sites More sharing options...
