mikem01 Posted February 20, 2019 Share Posted February 20, 2019 Looking for suggestions on new catalytic converters for my 05 gt. Car is completely stock so I'm not looking to upgrade or want anything that will need a tune. Sent from my XT1585 using Tapatalk Link to comment Share on other sites More sharing options...
Notorious Posted February 20, 2019 Share Posted February 20, 2019 Buying one through the exhaust shop that will weld it in for you may be cheaper than buying it yourself and having it installed. If you live in California or New York the replacement will need a CARB number or else you will fail visual smog inspections. Link to comment Share on other sites More sharing options...
whitetiger Posted February 20, 2019 Share Posted February 20, 2019 rockauto.com generally has them for fairly cheap if you want bolt-ons. Link to comment Share on other sites More sharing options...
BoozeRS05 Posted February 20, 2019 Share Posted February 20, 2019 Knowing what make and model you had would help us too. Many locals on this board or local classifieds might be of help with regard to good used parts. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
JmP6889928 Posted February 25, 2019 Share Posted February 25, 2019 Why does it need new catalytic converters? If they're fouled, you have something else going on to make them go bad. If all is right with the engine health, they are designed to basically last forever, so I would be looking at other reasons as to why they are bad. Link to comment Share on other sites More sharing options...
08SpecB_DE Posted February 26, 2019 Share Posted February 26, 2019 If you plan on keeping the car, buy factory cars. If you plan on selling in the next few months, buy aftermarket. Aftermarket cats generally last about a year, so while you save money upfront, it will bite you in the long run. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 26, 2019 Share Posted February 26, 2019 Lots of us take off the OEM down pipe which has cats and replace it with a 3" catted DP and a Cobb AP. The cars runs better and still passes emissions test. Gets better MPG too. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
