honeybunch2222 Posted February 8, 2019 Share Posted February 8, 2019 Hi, I have a little question for you guys, I have a 2009 GT, I will replace struts, install oem spring with tein lowering spring, replace balljoint and everything. But I'm not sure about control arms, the actual control arm is broken, and rusty. I check to install Spec B used from eBay in aluminum, but I'm not sure if the upgrade worth the money, can you guy tell me if it's really an upgrade with driving feel to use spec b control, or I can buy brand new steel one and replace the bushing in it ? Thanks guys :) Link to comment Share on other sites More sharing options...
The Yeti71 Posted February 8, 2019 Share Posted February 8, 2019 Look into some Mevotechs. You can find them on RockAuto. I changed mine out last spring. j. Link to comment Share on other sites More sharing options...
Notorious Posted February 8, 2019 Share Posted February 8, 2019 Mevotechs are the way to go. I might still have like a 5% off coupon for RockAuto if interested. Link to comment Share on other sites More sharing options...
whitetiger Posted February 8, 2019 Share Posted February 8, 2019 +1 for mevotech on rockauto. Link to comment Share on other sites More sharing options...
honeybunch2222 Posted February 8, 2019 Author Share Posted February 8, 2019 (edited) Yes I have checked the mevotech, tere are very interesting, I think the bushing are upgraded, they look better with not empty space, and balljoint are included. Do you feel a change in driving feeling? Edited February 8, 2019 by honeybunch2222 Link to comment Share on other sites More sharing options...
awfulwaffle Posted February 8, 2019 Share Posted February 8, 2019 Mine made a difference, but that was versus 150,000 mile stock arms. Can't say I felt anything in the way of reduced unspring weight from their being aluminum instead of steel, but I can say the fresh bushings made my car stop wobbling back and forth when stopping. Much tighter now. Link to comment Share on other sites More sharing options...
The Yeti71 Posted February 8, 2019 Share Posted February 8, 2019 Mine made a difference, but that was versus 150,000 mile stock arms. Can't say I felt anything in the way of reduced unspring weight from their being aluminum instead of steel, but I can say the fresh bushings made my car stop wobbling back and forth when stopping. Much tighter now. ^This^ Except mine were over 190k j. Link to comment Share on other sites More sharing options...
BoozeRS05 Posted February 8, 2019 Share Posted February 8, 2019 I first replaced my OE control arms that had torn bushings with another member's used steel arms that had Whiteline and AVO bushings installed on all corners. Those were nice, steering and control felt great and wasn't harsh by any means. But one day the driver side arm actually snapped backing into a parking space. No for sure idea why or how it happened, but definitely scary situation. I replaced that setup with the arms suggested above and they have been working great for over a year now. OE style rubber bushings seem solid and I'd say they drive similar to the aftermarket bushings I had on the used arms, but I'm feeling a lot more confident with this setup. EB's Subaru journal - 2005 LegacyGT Wagon & 2014 Forester FB25 (2008 specB - RIP) IG@legacygtliving Link to comment Share on other sites More sharing options...
