bobbydd21 Posted August 23, 2018 Share Posted August 23, 2018 I've been reading conflicting things about whether wear items, such as brake pads/rotors and wiper blades, are covered under the basic 3 year/36,000 factory warranty. I called my local Subaru dealer and was told that these are wear items and are not covered. Can anyone confirm one way or the other? Thanks! Link to comment Share on other sites More sharing options...
moral hazard Posted August 23, 2018 Share Posted August 23, 2018 Well I learned something new: https://www.subaru.com/owners/vehicle-warranty/warranties-2016.html Wear Item Limited Warranty WEAR ITEM COVERAGE is 3 years or 36,000 miles, whichever comes first. Items covered are brake pad/shoe linings, clutch linings, and wiper blades. But also keep in mind : Damage Caused Due to Use of Vehicle in Competitive Events These warranties do not cover damage to any component that is the result of operating the vehicle in any competition or racing event And commercial use is also excluded , I'm sure that includes uber / rideshare if they knew about it. Link to comment Share on other sites More sharing options...
TTG Posted August 23, 2018 Share Posted August 23, 2018 They have always replaced my wiper blades under warranty whenever I asked for a new set. I did not know about brake pads. Thats pretty cool. Link to comment Share on other sites More sharing options...
bobbydd21 Posted August 24, 2018 Author Share Posted August 24, 2018 Well I guess that settles that. My front rotors are definitely warped and I am very good/cautious with braking and my windshield wipers need to be replaced. Guess I’ll just make the appointment and if they give me any trouble I’ll show them the website. Link to comment Share on other sites More sharing options...
destruya Posted August 24, 2018 Share Posted August 24, 2018 Be sure to say you want your rotors *replaced* - otherwise you'll just get them resurfaced. Link to comment Share on other sites More sharing options...
securityguy Posted August 24, 2018 Share Posted August 24, 2018 Be sure to say you want your rotors *replaced* - otherwise you'll just get them resurfaced. You cannot dictate what they do. If the rotors are fine and only need a resurfacing, that is what they will do. If they find that they have to take off more metal than what will be within spec, then they will replace. You cannot tell them what to do;) Rotors can all be resurfaced once...it is a second time that you start to get out of specs for the thickness requirements for a rotor to be safe. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted August 24, 2018 Share Posted August 24, 2018 ^ they will most likely replace them as it is FASTER than turning them on a lathe... Link to comment Share on other sites More sharing options...
ammcinnis Posted August 24, 2018 Share Posted August 24, 2018 You cannot dictate what they do. If the rotors are fine and only need a resurfacing, that is what they will do. Correct. Subaru's obligation under warranty is the repair or replace, at their option. "If you don't know where you're going, any road will take you there." ~ The Cheshire Cat (Alice in Wonderland) Link to comment Share on other sites More sharing options...
tornichoe Posted August 25, 2018 Share Posted August 25, 2018 I had the wipers replaced on my OB and they did it with no questions asked. They actually changed the whole wiper and not just the insert. Subaru redesigned the wipers some time in 2017 I think. Bad thing in my case as I had purchased 4 sets of wiper inserts to use on both cars and now I have wiper inserts for 8 years or more for the legacy! Link to comment Share on other sites More sharing options...
