YeuEmMaiMai Posted August 10, 2018 Share Posted August 10, 2018 2014 Legacy, want to add a sub to the stock location on the shelf. what size will fit in there? Thanks, Link to comment Share on other sites More sharing options...
dgoodhue Posted August 10, 2018 Share Posted August 10, 2018 It is 8" in the HK system, I am not sure if all 8" Subwoofer will fit that location. Link to comment Share on other sites More sharing options...
Bootyologist Posted August 11, 2018 Share Posted August 11, 2018 2014 Legacy, want to add a sub to the stock location on the shelf. what size will fit in there? Thanks,a few people have used this guy https://www.amazon.com/dp/B00JQTU434/ref=cm_sw_r_cp_apa_Ju2BBb1YZ3T5B Sent from my Pixel XL using Tapatalk Link to comment Share on other sites More sharing options...
stewdogg Posted August 13, 2018 Share Posted August 13, 2018 a few people have used this guy https://www.amazon.com/dp/B00JQTU434/ref=cm_sw_r_cp_apa_Ju2BBb1YZ3T5B Sent from my Pixel XL using Tapatalk Do you have one? How does it compare to the stock sub? That's a pretty good price. Link to comment Share on other sites More sharing options...
Bootyologist Posted August 13, 2018 Share Posted August 13, 2018 Do you have one? How does it compare to the stock sub? That's a pretty good price.I don't, but there is a guy that did a great walk-through on here. if you search for the part number you should find it. I'd dig it up, but the search function on Tapatalk doesn't work. Sent from my Pixel XL using Tapatalk Link to comment Share on other sites More sharing options...
TDWPgtp Posted August 13, 2018 Share Posted August 13, 2018 A few points about aftermarket subs in the factory location: 1) the OEM subwoofer is specifically designed for use in a free-air installation, while nearly every aftermarket subwoofer requires a box. This is almost certainly a big deal for sound quality. I would be very surprised if most aftermarket subs sounded halfway decent in there. 2) the rear parcel shelf is probably not really stiff enough to support a much more powerful subwoofer than the factory one (although, it probably really isn't stiff enough for the OEM sub either) 3) I thought I had a "3" but I can't remember it now. Link to comment Share on other sites More sharing options...
