Hardware BoB Posted August 10, 2018 Share Posted August 10, 2018 Hey guys, thought I'd post here and show off my wagon. http://i.imgur.com/zNVAkU4l.jpg http://i.imgur.com/y6UlHAGl.jpg http://i.imgur.com/a63s5Y3.jpg http://i.imgur.com/5GFw223.jpg http://i.imgur.com/QqSaxtNl.jpg 2004 MY05 GT 2.0T 6MT Wagon, Arctic White Pearl. Performance EJ207 Short block (factory forged, lower compression) Crower valve springs with titanium retainers 3" custom dump pipe + cat, Fujitsubo cat back exhaust. Tech Edge 2J9 wideband O2 sensor Mamba GTX3071R Twin entry turbo PTP Turbo blanket Tomei expreme twin scroll headers. DEI titanium header/dump wrap ARP 625+ Head studs MY11 JDM STi cams Exedy HD clutch with aluminium lightweight flywheel. HDi FMIC kit (flipped to retain foglights) Kobe Motorsport silicone inlet OBX Blow off valve with full silicone recirc Custom trust/Greddy cold air intake K&N pod filter Walbro 460 with complete new wiring from battery Filter bypass and under bonnet filter Radium FPD-XR Turbosmart FPR1200 ID1000 Injectors aeroflow fuel rails with black braided PTFE/rubber lines and 6AN fittings. Pierburg 3 port BCS E85. Maintenance/Other: 7 row oil cooler with thermostat, mounted behind grille. Motul Sport 5W40 Fumoto quick drain oil plug LFR7AIX-P plugs Nulon sports shift performance 75W90 for gearbox/diff Dual custom catch can setup. Activated charcoal cabin filter Tactrix Openport 2.0 for tuning and logging BTSSM bluetooth K line ECU reader for logging. Upgraded engine and chasssis earths, additional earth to engine loom. Evans waterless coolant Handling/Stopping 85mm 6 speed and R180 from an 07 lib GT Spec B. Tuned by STi factory short shifter Brembos front and rear - painted metallic red Braided lines F+R Endless RF650 brake fluid Front and rear DBA T3 Rotors (rear 170mm adapter rotors) Project Mu HC800 pads F+R Cusco strut brace with master cylinder stopper Cusco rear tower brace STi front lower brace STi Group N pitch stop mount STi Group N gearbox mount STi Group N Engine mounts Whiteline W0506 LCA bushes Whiteline KCA334 anti lift kit Whiteline KCA313 Front Roll centre/bump steer - correction kit Beatrush by laile diff carrier Garage KM1 rear diff mount inserts. Truhart Rear Camber Arms Whiteline KTA124 Rear adjustable lateral arms Whiteline KCA307 Rear lateral arm lockout kit Shockworks coilovers. Coilover adjustment extensions to allow rear coilover adjustment without trim removal. 18x8.5 +44 Rota Gravel Yokohama Advan AD08R 235/40/18 Exterior HID lowbeam and high beam LED Exterior: parkers, number plate, reverse, brake, indicators, foglights. Tapturn indicator controller. JDM Spec B Front bar Genuine STi lip with lip extension. Genuine Front and Rear spats. Side skirt extensions Outback bonnet Corazone grille in black. tinted clear rear LED lights. Interior Spec B pedals 07 Tuned by STi door cards 07 Tuned by STi front seats Tuned by STi door sills Tuned by STi radio surround pieces Nappa leather red stitched gearboot, handbrake boot and centre console cover. Nappa leather red stitching inner kick panel trim Leather red stitched door grab handles DAMD D shaped red stitched steering wheel (post facelift shape) STi Airbag. STi 6MT shift knob Postfacelift steering wheel roll connector conversion. Kap Industries fire extinguisher bracket with SCA extinguisher. K2gear red stitched floor mats K2gear red stitched boot mat Custom gauge system - raspberry pi/arduino with 5" display custom mounted in Cubby. Custom dash cluster - Integrated 128x96 RGB OLED, 10,000 RPM tachometer, 300km/hr speedo, STi logos, temperature gauge delete and replace with boost gauge. LED Interior: courtesy, map,interior, cargo, vanity. JDM Clear door courtesy light bezels A118 1080p Dashcam Flip Key ICE Double DIN Fascia Steering wheel controls. Pumpkin quad core 1024x600 Android head unit with Telstra 3G Internet connection Reverse camera JVC KS-AX3205D 5 channel amp. Kicker Comp S 8 200W RMS in stock location. Tailgate and boot sound significant sound deadening I've just got four new speakers for the F+R doors and I am waiting on some new radium fuel rails - I've been chasing a fuel pressure issue for a while now, once that's fixed it should make 300kw on E85 - which is probably 450+ hp if you translate for an american dyno. I still have a laundry list of things to do on the car! Full build thread over at the liberty forums, http://forum.liberty.asn.au/viewtopic.php?f=10&t=27514 Link to comment Share on other sites More sharing options...
JmP6889928 Posted August 10, 2018 Share Posted August 10, 2018 The steering wheel is on the wrong side............. Link to comment Share on other sites More sharing options...
relative4 Posted August 10, 2018 Share Posted August 10, 2018 Truly outrageous. Link to comment Share on other sites More sharing options...
Mr-C Posted August 10, 2018 Share Posted August 10, 2018 Very nice!!!!!!!! Link to comment Share on other sites More sharing options...
legacybt Posted August 11, 2018 Share Posted August 11, 2018 That looks fantastic. Welcome! Link to comment Share on other sites More sharing options...
lilredwagon Posted August 11, 2018 Share Posted August 11, 2018 Car looks amazing! I love the boost gauge in the cluster! Welcome! Link to comment Share on other sites More sharing options...
BajanGT Posted November 25, 2018 Share Posted November 25, 2018 Respect!! Link to comment Share on other sites More sharing options...
MaasaiWarrior Posted November 26, 2018 Share Posted November 26, 2018 The steering wheel is on the wrong side............. actually made me LOL.... gorgeous wagon!! 08 Spec B, insta: @08_spec_b, 10 SH Forester insta: @shfozzy Link to comment Share on other sites More sharing options...
revilo Posted November 29, 2018 Share Posted November 29, 2018 Nice wagon. Did it come with factory steering wheel audio controls or was it something you added in? I've got an 04 JDM GTB and want to replace the wheel... Link to comment Share on other sites More sharing options...
