BLBostonLegacy Posted June 21, 2018 Share Posted June 21, 2018 I drive a 2005 legacy, and I need to replace all 4 struts and springs. Driver side front spring is broken passenger front is close to breaking, rear shocks are COMPLETELY shit. I want something a bit more aggressive then stock set up, but I don’t think I want to have to deal with making adjustments. I want to try to stay close too if not less than $1K. Link to comment Share on other sites More sharing options...
rapture Posted June 21, 2018 Share Posted June 21, 2018 Bilstien hds, ur choice of spring Spec b top hats Link to comment Share on other sites More sharing options...
theDiabolicaL1 Posted June 21, 2018 Share Posted June 21, 2018 Used JDM bilstiens? I just went through this myself including bushings. What a job... Link to comment Share on other sites More sharing options...
birdmayne Posted June 21, 2018 Share Posted June 21, 2018 Or Konis and good springs John Hancock Link to comment Share on other sites More sharing options...
VespaGTS Posted June 22, 2018 Share Posted June 22, 2018 I went with King springs. Just know this going in, you will decrease the ride quality buy lowering it. Handling will improve but there is a price to pay beyond the expense. If I was going to do it again I would install Bilstein with Pinks. Someone else can tell you which setup to go with either used JDM or new US market. The Pink springs shipped from Japan are $500. Struts with top hats new will be a bit more. Hi then you are done. Each thing added to the suspension system to “tighten it up” will increase the harshness of the ride. Link to my post about Koni with King springs. https://legacygt.com/forums/showthread.php/pictures-koni-struts-king-lowering-springs-before-after-pictures-269623.html?t=269623&highlight=Koni+king+springs Link to comment Share on other sites More sharing options...
rougeben83 Posted June 22, 2018 Share Posted June 22, 2018 Pinks are notorious for being stiffer than some of the aftermarket lowering options. If someone is looking to retain decent comfort over rough pavement, I would look elsewhere. Bilsteins or Koni's and whatever lowering spring you want. Link to comment Share on other sites More sharing options...
amm203 Posted June 22, 2018 Share Posted June 22, 2018 Koni/H&R kit is a great value & upgrade but you do sacrifice comfort. Hell if it doesn't corner flat as hell, though. Plus the mild 1"(+/-) drop looks perfect to me. Link to comment Share on other sites More sharing options...
relative4 Posted June 22, 2018 Share Posted June 22, 2018 I find the H&Rs very comfortable as well as excellent in the corners. A perfect balance in my opinion. If you have a wagon, you'll definitely want 1/2" saggy butt spacers. Sorry if I missed it in the stickies, but can anyone provide a general comparison of Koni vs Bilstein shocks? My stockers will hopefully die soon, waiting for an excuse to upgrade. Link to comment Share on other sites More sharing options...
BLBostonLegacy Posted June 24, 2018 Author Share Posted June 24, 2018 I don’t mind stock ride height, I live up in NH, I don’t need to plow the snow with my bumper, but I definitely want to increase handling in the corners. Link to comment Share on other sites More sharing options...
The Yeti71 Posted June 26, 2018 Share Posted June 26, 2018 I run pinks with my set up now. Not sure what all of the fuss is about the ride being "harsh". In fact, I think they smooth things out compared to OEM set up. Anyway, H&R, pinks, with Koni or Bilstein will make you pretty happy. Good luck! j. Link to comment Share on other sites More sharing options...
Dishwasher Posted June 26, 2018 Share Posted June 26, 2018 +1 for Koni and H&Rs. Solid setup for a daily driver, passes the pregnant wife comfort test. Brought to you by Pfizer Link to comment Share on other sites More sharing options...
