05MNLGT Posted December 15, 2018 Author Share Posted December 15, 2018 Ah width, that's it. Had not seen the comparison from that angle, thanks. Give this a shot for hazing. Pitting is a bit harder. Not sure on that yet. I'm going to try some film. Other then that you're basically stuck with sanding and 2k clear coat. Too bad the lenses are slightly different, could have swapped the lense over otherwise. actually they both are post facelift headlamps in the photo. i don't have my pre facelift set anymore. they are 2in wider than the pre facelift because of the wider bumper. the post facelift bumper is 6in wider in the front. Link to comment Share on other sites More sharing options...
05MNLGT Posted December 15, 2018 Author Share Posted December 15, 2018 here is kind of a comparison between the two. top is my old usdm (pre facelift) and the bottom is the S402 (post facelift). You can see how much the top of the fenders extend out. Link to comment Share on other sites More sharing options...
Somac Posted December 15, 2018 Share Posted December 15, 2018 one note. doing the jdm post facelift might be easier on a 08-09 LGT. i believe the low beam works as the drl. not sure about that. for 05-07, you have to disconnect the drl under the dash in order for the HID to work properly. I think the 08-09 USDM cars use the high beams at a reduced brightness (through PWM, I think) for the DRLs, so it makes it easier to convert to JDM HIDs since the DRLs won't mess with the HIDs if the DRLs are on the high beams. Link to comment Share on other sites More sharing options...
05MNLGT Posted December 15, 2018 Author Share Posted December 15, 2018 I think the 08-09 USDM cars use the high beams at a reduced brightness (through PWM, I think) for the DRLs, so it makes it easier to convert to JDM HIDs since the DRLs won't mess with the HIDs if the DRLs are on the high beams. yes that's it. Link to comment Share on other sites More sharing options...
05MNLGT Posted December 15, 2018 Author Share Posted December 15, 2018 if you haven't seen the jdm drls before, they're pretty cool. got things figured out, but i have to swap out the jdm plugs i put on the harness to run my current lights. Link to comment Share on other sites More sharing options...
05MNLGT Posted December 15, 2018 Author Share Posted December 15, 2018 here is the shield active and non-active. pretty cool. Link to comment Share on other sites More sharing options...
05MNLGT Posted December 16, 2018 Author Share Posted December 16, 2018 (edited) so if you want the bi-xenon HIDs headlamps, they should have two additional wires coming from the case. white and yellow. because of the age of these lamps, they might look like the same color. Edited December 16, 2018 by 05MNLGT Link to comment Share on other sites More sharing options...
xt2005bonbon Posted December 16, 2018 Share Posted December 16, 2018 if you haven't seen the jdm drls before, they're pretty cool. got things figured out, but i have to swap out the jdm plugs i put on the harness to run my current lights. I got these little led bulbs from the Russian source Pyro mentioned earlier. I love it. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted December 16, 2018 Share Posted December 16, 2018 (edited) here is the shield active and non-active. pretty cool. So looks like it is not using the same shield like the non washer model. What are you going to do to get the proper beam pattern? Looks tricky now. Edit: I just took a look at your picture again. It appears that it may be possible to flip that shield in there, but you're going to have to be very careful doing so. But regardless, having the bi-xenon feature is really great. I would love that. Edited December 16, 2018 by xt2005bonbon Link to comment Share on other sites More sharing options...
05MNLGT Posted December 16, 2018 Author Share Posted December 16, 2018 So knowing what you know now. Would it be easier to do a retro fit on the headlights with the washer set or that is not even an option based on the way the washer set is assembled. it would be easier on non bi-xenon set. i'm still working on the hid/high beam wiring. the answer i don't have is, does bi xenon only come on the washer set? my other set on the car currently was from unclemat. they were a shell and i didn't know there was a bi-xenon option, so i never looked. Link to comment Share on other sites More sharing options...
05MNLGT Posted December 16, 2018 Author Share Posted December 16, 2018 So looks like it is not using the same shield like the non washer model. What are you going to do to get the proper beam pattern? Looks tricky now. Edit: I just took a look at your picture again. It appears that it may be possible to flip that shield in there, but you're going to have to be very careful doing so. But regardless, having the bi-xenon feature is really great. I would love that. i thought about it, but knowing me, something would break. these lamps are 10+ yr old. they are brittle. they might be bi-xenon due to the cut off high beam. Link to comment Share on other sites More sharing options...
05MNLGT Posted December 16, 2018 Author Share Posted December 16, 2018 I got these little led bulbs from the Russian source Pyro mentioned earlier. I love it. so xt2005 how did you wiring your drls to get them to work? yes that's my plan too. to do the cross fire led. Link to comment Share on other sites More sharing options...
SubOperator Posted December 16, 2018 Share Posted December 16, 2018 Uhm, some more details? Headlights are what I want to mod next. Are your headlights JDM? I got these little led bulbs from the Russian source Pyro mentioned earlier. I love it. 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 248K 2007 B9 Tribeca Limited DGM - 258K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
05MNLGT Posted December 17, 2018 Author Share Posted December 17, 2018 i started the washer lamp installation. i pulled off the driver side non washer lamp. looked inside and it isn't a bi-x. so at this point i would say that bi-x only comes on the washer lamps. Link to comment Share on other sites More sharing options...
05MNLGT Posted December 17, 2018 Author Share Posted December 17, 2018 (edited) getting there. here is a pic of the washer tank and lines. since the bumper is off, thought you'd like to see the beam and support. Edited December 17, 2018 by 05MNLGT Link to comment Share on other sites More sharing options...
05MNLGT Posted December 17, 2018 Author Share Posted December 17, 2018 when i'm too lazy to put it on the lift, i use my ikea mat. off an ikea chair. soooo nice to work on it. fun times emptying a full washer tank. Link to comment Share on other sites More sharing options...
05MNLGT Posted December 17, 2018 Author Share Posted December 17, 2018 here are the two tanks. the jdm is slightly different, more the mounting points. mounts to the chasisy just like the usdm, but it doesn't align to the three mounting point. which is fine, just rig it up with a small zip tie. also the pumps on the jdm are exposed vs the cover over the pumps on the usdm version. other then those little things, it went in fine. used my pumps for now. need to figure out the relay and jdm wiring for the pumps and motor. Link to comment Share on other sites More sharing options...
05MNLGT Posted December 18, 2018 Author Share Posted December 18, 2018 installed. i'll get a picture of the drls tomorrow. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted December 18, 2018 Share Posted December 18, 2018 so xt2005 how did you wiring your drls to get them to work? yes that's my plan too. to do the cross fire led. Sorry. Just saw your question... Actually, mine are not cross fire led. I got these: I have actually unplugged the white plug from the DRL module. And I will tap on a positive wire from the fuse box for these little LEDs. (see this post) On a side note I also installed double filament orange bulbs in the turn signal slots. Got the bulbs from autozone. I believe they fit the Chevrolet Spark. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted December 18, 2018 Share Posted December 18, 2018 Uhm, some more details? Headlights are what I want to mod next. Are your headlights JDM? Yes JDM. I got the nose cut about two months ago, and installed everything about a month ago. I should have made a build thread to document the work . There's still one available from my local jdm vendor. https://www.ebay.com/itm/JDM-Subaru-Legacy-Outback-06-And-Up-Bumper-Headlights-Fenders-Hood/273153723933?hash=item3f993b0e1d:g:B3kAAOSwgc1azQgg:rk:37:pf:0 So yeah. Keep in mind that the JDM and USDM headlights have slightly different shape, even though it does not appear so. Link to comment Share on other sites More sharing options...
05MNLGT Posted December 18, 2018 Author Share Posted December 18, 2018 Sorry. Just saw your question... Actually, mine are not cross fire led. I got these: I have actually unplugged the white plug from the DRL module. And I will tap on a positive wire from the fuse box for these little LEDs. (see this post) On a side note I also installed double filament orange bulbs in the turn signal slots. Got the bulbs from autozone. I believe they fit the Chevrolet Spark. split the signal and parking light. parking light is tied into the drl now. it's temp, but i do like being able to shut off the drls. Link to comment Share on other sites More sharing options...
05MNLGT Posted December 18, 2018 Author Share Posted December 18, 2018 hate it, hate it. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted December 18, 2018 Share Posted December 18, 2018 split the signal and parking light. parking light is tied into the drl now. it's temp, but i do like being able to shut off the drls. Yeah. I will not be able to shut off the DRL unless I add a switch and relay. But meh, it's OK. They'll turn on with ignition and will remain on. That's OK for now. On the other hand, I like the fact that when I turn the combination switch one notch, my parking lights turn on but not the HID. Looks pretty cool actually. Link to comment Share on other sites More sharing options...
MaasaiWarrior Posted December 18, 2018 Share Posted December 18, 2018 Sorry. Just saw your question... On a side note I also installed double filament orange bulbs in the turn signal slots. Got the bulbs from autozone. I believe they fit the Chevrolet Spark. Correct! I just saw this thread, the turn signals are the same bulb as the chevy spark rear turn signal. I did this swap last year and it took me a while to figure it out, I went into the GM dealer with the wierd part number and the guy said he had never seen a part number like it, punched it in and it came up. He couldn't believe it. 08 Spec B, insta: @08_spec_b, 10 SH Forester insta: @shfozzy Link to comment Share on other sites More sharing options...
MaasaiWarrior Posted December 18, 2018 Share Posted December 18, 2018 when i'm too lazy to put it on the lift, i use my ikea mat. off an ikea chair. soooo nice to work on it. fun times emptying a full washer tank. Love the idea! I was just at ikea on saturday too. I know what I'm buying next time I'm there 08 Spec B, insta: @08_spec_b, 10 SH Forester insta: @shfozzy Link to comment Share on other sites More sharing options...
