Gabo Posted May 12, 2018 Share Posted May 12, 2018 Glad to hear parameters are within normal range. Link to comment Share on other sites More sharing options...
VespaGTS Posted May 12, 2018 Author Share Posted May 12, 2018 Glad to hear parameters are within normal range. No kidding. What a ride! Looks like I get the OBDlink afterall. Link to comment Share on other sites More sharing options...
VespaGTS Posted May 12, 2018 Author Share Posted May 12, 2018 I spoke too soon. Went on a bit longer drive today and it all fell apart. DAM went to 0.125 Feedback Knock -8.0 Feedback knock learn-5.5 Boost at 17.94 I think it’s overboosting. I will check for a hole in the turbo to throttle body connection. Boost test is the one I have not done yet. Good news is the fueling is still spot on. Link to comment Share on other sites More sharing options...
relative4 Posted May 13, 2018 Share Posted May 13, 2018 A log including boost target, TD boost error, knock sum, IAM, timing, etc. may help point in the right direction. A learning view snapshot would also be helpful. You may want to consider escalating this one from internet forums to hands-on expert assessment. Link to comment Share on other sites More sharing options...
VespaGTS Posted May 13, 2018 Author Share Posted May 13, 2018 I will check the TB to Turbo hose if thats good then off to the mechanic it goes. Link to comment Share on other sites More sharing options...
VespaGTS Posted May 14, 2018 Author Share Posted May 14, 2018 Log going from bad to worse with all categories checked for your viewing pleasure. Not doing another one. Off to the tuner I go...datalog3.csv Link to comment Share on other sites More sharing options...
relative4 Posted May 14, 2018 Share Posted May 14, 2018 Yeah, that's wise. I just wonder if it might be something as simple as a bad MAF sensor. Link to comment Share on other sites More sharing options...
VespaGTS Posted May 14, 2018 Author Share Posted May 14, 2018 I am very suspicious of the MAF simply because it ran so well after I cleaned it last time around. I'll pick up a Denso and report back. Link to comment Share on other sites More sharing options...
VespaGTS Posted May 15, 2018 Author Share Posted May 15, 2018 MAF sensor installed AF/1C was at 7.0 and now it is at .08 Knock is at 0 during WOT pull. DAM is still at .812 but it needs to calibrate. Here is the file. Note to all who might read this. If you car has more than 100k on it just replace the MAF. If DAM does not improve I will replace the front O2 sensor as well. Whew!datalog5.csv Link to comment Share on other sites More sharing options...
VespaGTS Posted May 15, 2018 Author Share Posted May 15, 2018 Back to 1.0 on DAM and 0 knock across the board. Lets hope this was the solution. Link to comment Share on other sites More sharing options...
solidxsnake Posted May 15, 2018 Share Posted May 15, 2018 Sounds like the MAF was the culprit, and as you found, they can go bad before any MIL or other indication. The front O2 sensor is also known to go bad in the same way, so for peace of mind, it wouldn't be a bad idea to swap that out as well. The rear O2 sensor may throw a MIL if it goes bad, but it won't affect the car's operation, and you can disable that MIL and the rear O2 sensor's contribution to the fuel trims via tuning, so it's less of a concern. Sometimes, I wonder if the MAF itself is fine, but the pins in the connector get mucked up. I know on my LGT, when I fiddle with the wires on the MAF sensor, my intake air metering will change drastically sometimes. Link to comment Share on other sites More sharing options...
VespaGTS Posted May 15, 2018 Author Share Posted May 15, 2018 I am so very happy its over for now. You are right, I should just order the O2 sensor and be done with it. The peace of mind is well worth it. Link to comment Share on other sites More sharing options...
