YeeeeOk Posted March 26, 2018 Share Posted March 26, 2018 Hey guys, been searching the forums for quite some time and haven't found my answer. Was wondering if I could fit a 18x8.5 +20mm offset for the front and 18x10 +20mm offset for the rear, on my lowered 2013 subaru legacy 3.6r. If someone could help me out it would be great. Link to comment Share on other sites More sharing options...
Humble Rumble Posted March 26, 2018 Share Posted March 26, 2018 Heavily not recommended to run a staggered setup on a symmetrical AWD drive. Even if the diameters are the same, you're putting unnecessary strain on the drivetrain and diffs that can lead to pre-mature wear and breakage. As for the specific sizes you asked for, 18x8.5 +20 will fit, probably be a bit heavy on the poke though. I'd recommend finding an offset for that size closer to around +30 to +45. 18x10 +20 will almost assuredly NOT fit at all without heavy fender modification including rolling, likely pulling, and definitely needing camber (which our cars do not have adjustable stock, so you'll need adjustable rear lower control arms as well). I would stay away from this size and this general setup overall personally. 2012 Legacy 3.6R Build Thread 5th Gen Legacy BM/BR Body Kit Compendium Thread Link to comment Share on other sites More sharing options...
YeeeeOk Posted March 26, 2018 Author Share Posted March 26, 2018 Heavily not recommended to run a staggered setup on a symmetrical AWD drive. Even if the diameters are the same, you're putting unnecessary strain on the drivetrain and diffs that can lead to pre-mature wear and breakage. As for the specific sizes you asked for, 18x8.5 +20 will fit, probably be a bit heavy on the poke though. I'd recommend finding an offset for that size closer to around +30 to +45. 18x10 +20 will almost assuredly NOT fit at all without heavy fender modification including rolling, likely pulling, and definitely needing camber (which our cars do not have adjustable stock, so you'll need adjustable rear lower control arms as well). I would stay away from this size and this general setup overall personally.Thanks for the quick response, I'm going to try and find the 18x8.5 with a +35 offset for all four wheels. Sent from my SM-G925W8 using Tapatalk Link to comment Share on other sites More sharing options...
Perscitus Posted March 26, 2018 Share Posted March 26, 2018 Try to stick to 18x8.5 +40 or +45. +35 might require a pull/roll. Link to comment Share on other sites More sharing options...
Zee199969 Posted March 26, 2018 Share Posted March 26, 2018 I'm lowered on RCE blacks (~0.8" drop) and have 18x8.75 +36. When I had 245/40/18 tires there was no rubbing at all. When I went up to 255/40/18 there was a slight rub (only on big dips) and I rolled the fenders. My "Build" Link to comment Share on other sites More sharing options...
YeeeeOk Posted March 27, 2018 Author Share Posted March 27, 2018 Try to stick to 18x8.5 +40 or +45. +35 might require a pull/roll.Dam, was inpatient and pulled the trigger on them. I have my fenders rolled already not sure if there pulled. If anything I'll give it a slight camber to tuck them in if it's possible Sent from my SM-G925W8 using Tapatalk Link to comment Share on other sites More sharing options...
Becks1818 Posted March 27, 2018 Share Posted March 27, 2018 Try to stick to 18x8.5 +40 or +45. +35 might require a pull/roll.+35 won't need a roll. I test fitted mine and everything cleared no problem . 18", 8.5", +35 offset , 245/40/18 tire. Link to comment Share on other sites More sharing options...
Perscitus Posted March 27, 2018 Share Posted March 27, 2018 Sounds good - that low profile must be helping as the tire tucks in during suspension travel. Link to comment Share on other sites More sharing options...
Humble Rumble Posted March 27, 2018 Share Posted March 27, 2018 Yeah 18x8.5 +35 will fit fine all the way around, pending tire size. 245/40 is a pretty good size of tire for that size wheel, but depending how much you're dropped you could lose a bit of sidewall or tire width if you're worried about rubbing, but you should honestly be fine unless you're completely slammed. 2012 Legacy 3.6R Build Thread 5th Gen Legacy BM/BR Body Kit Compendium Thread Link to comment Share on other sites More sharing options...
cww516 Posted March 27, 2018 Share Posted March 27, 2018 I want to say swannee was running 18x8.5 +38 with either 245/40R18 or 245/45R18 tires, no fender mods. Based on that, I'd imagine +35 plus your preexisting roll should be fine. Link to comment Share on other sites More sharing options...
dgoodhue Posted March 27, 2018 Share Posted March 27, 2018 My car with 245/45-18 (taller than stock) tires, 18 x 8.5" rims with 30mm offset with 1" lowering springs barely fit (lightly touched) with a roll and pull. I would imagine 35mm with be fine with rolled fenders or slight pull. Link to comment Share on other sites More sharing options...
