illt3ck Posted October 26, 2005 Share Posted October 26, 2005 I have my heart set on these bad boys so now I'm looking for a deal. If you already own them - please post where you bought them from and for how much. If you've spotted a great deal please let me know!! Thanks! Link to comment Share on other sites More sharing options...
axis008 Posted October 27, 2005 Share Posted October 27, 2005 Wait, they don't make this for the Legacy, though... Do they???? -ben Link to comment Share on other sites More sharing options...
RaceComp Engineering Posted October 27, 2005 Share Posted October 27, 2005 PM sent! I have my heart set on these bad boys so now I'm looking for a deal. If you already own them - please post where you bought them from and for how much. If you've spotted a great deal please let me know!! Thanks! Link to comment Share on other sites More sharing options...
PGT Posted October 27, 2005 Share Posted October 27, 2005 if these are the cockpit adjustable ones, then they aren't made for the LGT....at least when I asked Myles from RaceComp about a month ago. Link to comment Share on other sites More sharing options...
illt3ck Posted October 27, 2005 Author Share Posted October 27, 2005 if these are the cockpit adjustable ones, then they aren't made for the LGT....at least when I asked Myles from RaceComp about a month ago. Whoops! I guess I meant the Cusco Zero 2 - not the 2e Link to comment Share on other sites More sharing options...
PGT Posted October 27, 2005 Share Posted October 27, 2005 I'd like to buy the Zero 2e version....might just be a matter of time Link to comment Share on other sites More sharing options...
axis008 Posted October 28, 2005 Share Posted October 28, 2005 Oooh. Okay. Haha. I want the in-car adjustable ones. For my non-existent Legacy. Cusco please make it and I'll pretend to buy one! -ben Link to comment Share on other sites More sharing options...
Mines Posted October 29, 2005 Share Posted October 29, 2005 how much are cusco zero 2 coilovers? I have never seen them available on any vendor Link to comment Share on other sites More sharing options...
Waxiboy Posted October 29, 2005 Share Posted October 29, 2005 are noises and clunks pretty much a given when installing coilovers? i have my eyes set on these but it seems the noise factor turns me off Link to comment Share on other sites More sharing options...
03Indigo Posted November 1, 2005 Share Posted November 1, 2005 how much are cusco zero 2 coilovers? I have never seen them available on any vendor RalliTek has them, they are around $2K. I have a set on my OBXT right now. They will be coming off soon to go to another board member here. SnoDork is also running them on his wagon. Great set up. Link to comment Share on other sites More sharing options...
03Indigo Posted November 1, 2005 Share Posted November 1, 2005 are noises and clunks pretty much a given when installing coilovers? i have my eyes set on these but it seems the noise factor turns me off To some extent...yes. Teh springs are on solid metal perches. in an OEM set up, there are rubber fittings that seat the springs, this reduces the noise and rattles. since the coilovers are adjustable, having a rubber seat on the perch would basically make it impossible to adjust them, (very difficult to rotate the perch while under load when adjusting height.) I have only notice small, very small, rattles at very low parking lot speeds. but once over about 10mph, they go away. I do hear a "swish" noise when going over speed bumps...this is a product of the dampers working...I really like that, sounds like a small BOV. Betsy loves the noise they make, she get's a kick out of them. Overall, coilovers are way worth it, they are adjustable, and can be tuned to fit your needs. The Cusco's have one of the higher spring rates, so they are a bit stiffer, almost eliminating the need for sway bars. You can see from the top hat, in the attachments above, that the fronts are adjustable from the inside of the engine bay, the rears have to be taken out, or a small access hole cut into the panel that covers it from the inside of the car. I was about to do this on my car, cutting about a 1" circle and getting a filler cap to cover it. That way I can get in there and turn the dial with a small screw driver without having to pull the rears out to adjust them. That pretty much holds true for most coilovers for our cars...they adjust the same way. Link to comment Share on other sites More sharing options...
Xenonk Posted November 1, 2005 Share Posted November 1, 2005 how much are cusco zero 2 coilovers? I have never seen them available on any vendor http://www.gtworx.com http://www.racecompengineering.com Keefe Link to comment Share on other sites More sharing options...
Waxiboy Posted November 2, 2005 Share Posted November 2, 2005 do you guys know the pre set drop of these out of the box? Link to comment Share on other sites More sharing options...
