gt350son Posted September 27, 2017 Share Posted September 27, 2017 Hey guys. I think my turbos exhaust oil seal is blown. 06 Legacy GT, total 180k miles, 5k on short block, maybe 180k on turbo not sure if its been replaced or not since i've owned the car since 160k. Haven't driven it in for 2 months, but this is what I remember. It started to burn oil out of the exhaust. Seems to only burn on warm starts and continues to burn for about 5-10 minutes of driving. I have checked the intake side of the turbo and the intercooler is completely clean no evidence of oil. However the exhaust side of the turbo was covered in oil except for the turbine. Here is a picture of the exhaust housing. The top of the housing of damp, but the bottom is dripping wet if you couldn't see in the picture. Link to comment Share on other sites More sharing options...
bigBADbenny Posted September 27, 2017 Share Posted September 27, 2017 Apart from looking for leaks from the turbo oil feed and oil drain, you'll want to confirm if the PCV and carter ventilation systems are blocked causing excessive crank case presure, in turn forcing oil out of the turbo bearings... Link to comment Share on other sites More sharing options...
gt350son Posted September 28, 2017 Author Share Posted September 28, 2017 Thanks. When I get my hands on it I'll have to double check that the last shop reinstalled my air/oil separator correctly. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 28, 2017 Share Posted September 28, 2017 How much movement is in that wheel, check up/down, in/out ? JmP6889928 is the trusted member who rebuilds them. My tuner http://www.tuningalliance.com will rebuild it too. Why was the engine replaced ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
gt350son Posted September 29, 2017 Author Share Posted September 29, 2017 I've checked the movement and it seems fine. Engine was replaced from the bearings wearing out, easier for me at the time to get a oem shortblock. Yea I am contacted him and he suggested I check the pcv system. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted September 29, 2017 Share Posted September 29, 2017 When my oil seal went I had the same issue except excessive shaft play on both axis. If you remove you IC and its equally as drenched you def need to look over the PCV Link to comment Share on other sites More sharing options...
