08spec.b. Posted September 8, 2017 Share Posted September 8, 2017 Hello so I'm trying to purchase a BOV for my spec.B. I know obviously they come equipped with one from the factory but I'd like one that's louder! My buddy was telling me I can just get a spacer for it which would give me that sound that I crave? Who sells them? Also what's the cheapest route? Thanks -Tony Link to comment Share on other sites More sharing options...
robburns201 Posted September 8, 2017 Share Posted September 8, 2017 turbo smart Dual port....Just put this on and you could do a 50/50 and get the best of both worlds.. Link to comment Share on other sites More sharing options...
08spec.b. Posted September 8, 2017 Author Share Posted September 8, 2017 I spoke to someone at cobb and they said it's not recommended to put an after market bov or anything cause our cars are tuned a certain way and it wouldn't run right? Link to comment Share on other sites More sharing options...
Max Capacity Posted September 8, 2017 Share Posted September 8, 2017 Take out the silencer under the air filter box, you'll get a little noise from that. Ask Dave at cyro tuning what he would recommend for you. http://www.cryotuneperformance.com/ He's the only one near you'd I'd trust my car too. Tell him we sent you to him. Is the car on a Cobb AP ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
08spec.b. Posted September 10, 2017 Author Share Posted September 10, 2017 It's not on a cobb ap yet.... I'm going to buy one next month. Will it Run poorly just by putting on a aftermarket BOV? Link to comment Share on other sites More sharing options...
Max Capacity Posted September 10, 2017 Share Posted September 10, 2017 FWIW, both my cars have OEM BOV's. spend you money on something more important. The catless DP on and current exhaust set up on my wagon, let me hear the turbo and BOV really clear. stock mid pipe and straight thru mufflers from Pro Lab Tuning. Read more about these cars and then ask again when you have more questions. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
BDII Posted September 10, 2017 Share Posted September 10, 2017 Subarus have BOVs? Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
spacemanspif Posted September 10, 2017 Share Posted September 10, 2017 The turbo GTs have a by-pass valve, which functions the same as a blow off valve to relieve boost pressure. The by-pass puts the air back into the intake system because of the way subaru designed the system and the tune. Switching to a blow off valve causes issues when you let off the gas pedal while boosting. Link to comment Share on other sites More sharing options...
ehsnils Posted September 10, 2017 Share Posted September 10, 2017 Subarus have BOVs? Riced out Subies do. Link to comment Share on other sites More sharing options...
solidxsnake Posted September 10, 2017 Share Posted September 10, 2017 http://legacygt.com/forums/showthread.php/technical-info-bov-bpv-set-up-and-operation-150687.html Link to comment Share on other sites More sharing options...
MrMileHighGuy Posted September 12, 2017 Share Posted September 12, 2017 I agree. Start with worth while mods, like preventative maintenance, catless up pipe, downpipes, tune, remove banjo filters, exhaust if you want more sound. Link to comment Share on other sites More sharing options...
08spec.b. Posted September 12, 2017 Author Share Posted September 12, 2017 FWIW, both my cars have OEM BOV's. spend you money on something more important. The catless DP on and current exhaust set up on my wagon, let me hear the turbo and BOV really clear. stock mid pipe and straight thru mufflers from Pro Lab Tuning. Read more about these cars and then ask again when you have more questions. I've been checking out your engine build in your signature. That's the way I want to go. Something simple but fun to drive. Power and noise when I choose! Also problem free as much as possible. I've driven Volkswagen growing up. All this stuff is new to me haha I apologize in advance if I ask you guys/girls stupid questions I'm still learning these amazing machines. Link to comment Share on other sites More sharing options...
Max Capacity Posted September 12, 2017 Share Posted September 12, 2017 Thanks, it really is that easy to have a great DD. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
