Whopper Posted August 24, 2017 Share Posted August 24, 2017 My turbo was broke so I removed it. Can I still drive if I plug all the lines? Will my engine blow up? Link to comment Share on other sites More sharing options...
Eugene Onegin Posted August 25, 2017 Share Posted August 25, 2017 I can't speak for turbos but my Brother has a car with a super charger ( Pontiac ) and it ran just fine with the blower disconnected . Link to comment Share on other sites More sharing options...
xtea Posted August 25, 2017 Share Posted August 25, 2017 Your engine might blow up. We need much more details. Broke turbos cause terminal engines. Also, ask a tuner who knows subarus. Dont drive it because some random on the internet says hes got a brother who took a supercharger off some other make model. Ecus are the opposite of created equal. Link to comment Share on other sites More sharing options...
Whopper Posted August 25, 2017 Author Share Posted August 25, 2017 Your engine might blow up. We need much more details. Broke turbos cause terminal engines. Also, ask a tuner who knows subarus. Dont drive it because some random on the internet says hes got a brother who took a supercharger off some other make model. Ecus are the opposite of created equal. Its A 94 Legacy sport EJ22t its the closed deck version of the ej22 and its like to a 22b. Im only scared that the vac lines that connected to the air intake before the turbo wont have enough vacuum and It might run real rich because it has a chip in it to give it more gas. Link to comment Share on other sites More sharing options...
Whopper Posted August 25, 2017 Author Share Posted August 25, 2017 And a tuner who does allot of jdm mostly honda said it should run but the ecu will just run normal in the vacuum maps. Link to comment Share on other sites More sharing options...
xtea Posted August 25, 2017 Share Posted August 25, 2017 And a tuner who does allot of jdm mostly honda said it should run but the ecu will just run normal in the vacuum maps. I would ask a subie tuner. Email Cryotune or tuning alliance. Things that work on other cars usually dont work the same on ours. Link to comment Share on other sites More sharing options...
Infosecdad Posted August 25, 2017 Share Posted August 25, 2017 Assuming you have a different header and midpipe? Link to comment Share on other sites More sharing options...
Whopper Posted August 25, 2017 Author Share Posted August 25, 2017 Im not going to risk it. Im just am going to get a new turbo. Link to comment Share on other sites More sharing options...
solidxsnake Posted August 25, 2017 Share Posted August 25, 2017 You'll need to re-tune it if you get rid of the turbo. The fueling/timing will be all off with no boost being built. However, it won't destroy anything (except for maybe your cats), since it'll tend to run rich. This is assuming that the block itself isn't loaded with metal shavings from the dead turbo. Link to comment Share on other sites More sharing options...
Whopper Posted August 25, 2017 Author Share Posted August 25, 2017 You'll need to re-tune it if you get rid of the turbo. The fueling/timing will be all off with no boost being built. However, it won't destroy anything (except for maybe your cats), since it'll tend to run rich. This is assuming that the block itself isn't loaded with metal shavings from the dead turbo. Not dilled with metal shavings but their was allot of nasty grim that is infront of the throttle body hopefully not in my engine Link to comment Share on other sites More sharing options...
