TheUnsungWar Posted January 9, 2018 Share Posted January 9, 2018 So I am having a problem with the passenger side OVS. I have read about knocking the bracket out of the way but I don't think thats my problem. It slides right past it and then is stopped by the hoses in front of it. Any idea whats in those hoses? I will try and upload some photos. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted January 9, 2018 Share Posted January 9, 2018 This should help you: http://forum.liberty.asn.au/viewtopic.php?f=10&t=30105 Link to comment Share on other sites More sharing options...
TheUnsungWar Posted January 9, 2018 Share Posted January 9, 2018 Hey hey @xt2005bonbon for the win. That helps so much. Time to continue the work. Link to comment Share on other sites More sharing options...
TheUnsungWar Posted January 9, 2018 Share Posted January 9, 2018 So I believe I got the OVC switched. I don't have to turn the engine over to check the pending CELs, correct? I read on another thread it takes 2 15 mile drives for these codes to pop up again after resetting. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted January 9, 2018 Share Posted January 9, 2018 The engine has to run so it can check the ocv angles. If one of them is not working properly, it will throw a code. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted January 9, 2018 Share Posted January 9, 2018 And if you had the btssm app, you would want to log the 'vvt angles L/R'. Unit is in degrees. Both values should always be in sync. If one is not working properly, it will be obvious. Link to comment Share on other sites More sharing options...
TheUnsungWar Posted January 9, 2018 Share Posted January 9, 2018 I just got it. I'll see if I can find those values while it runs. Any chance there is a known admin around? I am having problems uploading photos to the forum album. Reason is when I took off the hoses blocking the OVC path, there is a ton of white gunk in it. O.o Wanted to upload a photo of it to get some advice. Link to comment Share on other sites More sharing options...
TheUnsungWar Posted January 9, 2018 Share Posted January 9, 2018 Max Capacity gave me a contact. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted January 9, 2018 Share Posted January 9, 2018 Those are breather hoses. White gunk may be a sign of coolant in oil? Others can chime in. do you have a vag-com cable? Link to comment Share on other sites More sharing options...
TheUnsungWar Posted January 9, 2018 Share Posted January 9, 2018 Yeah so my Veepeak ecu bluetooth adapter isn't compatible with BTSSM apparently. T-T Turned the car on and the turbo started whining.... more T-T Link to comment Share on other sites More sharing options...
TheUnsungWar Posted January 9, 2018 Share Posted January 9, 2018 Those are breather hoses. White gunk may be a sign of coolant in oil? Others can chime in. do you have a vag-com cable? I do not have one. I have the bluetooth adapter previously mentioned. Just in case, there is no saving a turbo once it starts to whine right?? T-T Link to comment Share on other sites More sharing options...
Darth SpecB Posted January 9, 2018 Share Posted January 9, 2018 I do not have one. I have the bluetooth adapter previously mentioned. Just in case, there is no saving a turbo once it starts to whine right?? T-TI agree with coolant being in pcv system. You can have the turbo rebuilt, if the housing isn't damaged too badly. Sent from my SM-G950U using Tapatalk Link to comment Share on other sites More sharing options...
TheUnsungWar Posted January 9, 2018 Share Posted January 9, 2018 I agree with coolant being in pcv system. You can have the turbo rebuilt, if the housing isn't damaged too badly. Sent from my SM-G950U using Tapatalk I am guessing I have to call around to see if the shops perform that service? Or is it another DYI project? Is there a way to check the pvc system for the possible leak? Link to comment Share on other sites More sharing options...
TheUnsungWar Posted January 9, 2018 Share Posted January 9, 2018 Another question regarding the Banjo Bolt. Does it have to be facing a specific way? Like the holes must be facing front of car/firewall, or just screw it in? Link to comment Share on other sites More sharing options...
xt2005bonbon Posted January 9, 2018 Share Posted January 9, 2018 Regarding rebuilding the turbo, we have a member on our forum who does a very good job at it. jmp something is his username . someone else will provide his actual username. And regarding the banjo bolt orientation, no it does not matter how it is facing. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 9, 2018 Share Posted January 9, 2018 JmP6889928 has taken a break from offering that service. Mike at tuningalliance@gmail.com will also rebuild it for you. Oh he's also one of the best Tuners too. Let Mike know I sent you. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
TheUnsungWar Posted January 23, 2018 Share Posted January 23, 2018 Any way to check the OVCs beside Btssm or a 9V(which just checks if it functions)? Link to comment Share on other sites More sharing options...
xt2005bonbon Posted January 23, 2018 Share Posted January 23, 2018 Have you ever swapped them? Link to comment Share on other sites More sharing options...
TheUnsungWar Posted January 23, 2018 Share Posted January 23, 2018 ^ Yeah I swapped them. Then the turbo started squealing so I turned it off before i could get the code to check. Kind of afraid to turn it back on Link to comment Share on other sites More sharing options...
aj_mariner Posted January 24, 2018 Share Posted January 24, 2018 I wouldn’t turn it back on...get a new turbo from one of the tuning vendors here, or buy from online Subaru parts wholesaler. While your at it, dump your oil and refresh Link to comment Share on other sites More sharing options...
xt2005bonbon Posted January 24, 2018 Share Posted January 24, 2018 Drop the downpipe and check for shaft play. Link to comment Share on other sites More sharing options...
aj_mariner Posted January 24, 2018 Share Posted January 24, 2018 ^^^This...as well as any indication of the turbine or compressor blades rubbing on the housing. Link to comment Share on other sites More sharing options...
TheUnsungWar Posted July 10, 2018 Share Posted July 10, 2018 So I managed to get the turbo off, get it inspected (came back good) reassemble and turn on the car with the btssm app. 2 things: it's showing negative boost pressure (3-5) and the vvt's are different 17-15 and 14-11. Never the same at one time. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted July 10, 2018 Share Posted July 10, 2018 Are these VVT values at idle, under load? In any case, if there are not in sync, then probably time to replace them. Can't remember: did you replace/toss both banjo bolt filters? Link to comment Share on other sites More sharing options...
TheUnsungWar Posted July 10, 2018 Share Posted July 10, 2018 The one under the turbo had a filter, so I removed it. The ovcs didn't have one. Didn't check the one behind the Serpentine. And it was at idle. What about the negative air pressure? I remember it being about 18. Link to comment Share on other sites More sharing options...
