devobuzz Posted June 24, 2017 Share Posted June 24, 2017 So doing my timing belt and will drain the radiator. Since all my hoses are 13 years old, I was thinking of replacing all the coolant hoses while I was at it. Apparently there are more hoses than I thought. I have the radiator upper/lower but do all of these other hoses normally wear out/dry rot? Here's what I found so far: turbo coolant hose throttle body coolant hose (are there 2 there?) coolant fill reserviour - 3 hoses connected there waters pump inlet/outlet hoses heater hoses in/out maybe I can use straight hose instead of these molded ones? Thanks. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 24, 2017 Share Posted June 24, 2017 The molded ones are not that much money in the bigger picture. I used NAPA hoses for the top and bottom and OEM for the heater, oil cooler and turbo cooling. My other coolant hoses are still original. Change out the ones that are easy while your there. How's your coolant cross over pipe ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
devobuzz Posted June 24, 2017 Author Share Posted June 24, 2017 Where is the coolant cross over pipe? I see a rusty pipe below the belts between radiator and engine that has me worried. Link to comment Share on other sites More sharing options...
MilesA Posted June 24, 2017 Share Posted June 24, 2017 Where is the coolant cross over pipe? I see a rusty pipe below the belts between radiator and engine that has me worried.The crossover pipe is on top of the engine, under the intake manifold. The upper radiator hose connects to it. Similar to illustration below, #12. The lower pipe rusts from the exhaust heat. "They all do that" after a few years, so no need to worry, just keep an eye on it. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 24, 2017 Share Posted June 24, 2017 It's the lower pipe I was talking about. I replaced mine when I had the engine out. It sends coolant to the oil cooler, I replaced all those small hoses too. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
devobuzz Posted June 24, 2017 Author Share Posted June 24, 2017 Yeah that pipe is pretty bad. it looks like there is a rubber hose on each end. One from water pump and one to oil cooler. Definitely will replace that. Link to comment Share on other sites More sharing options...
devobuzz Posted June 24, 2017 Author Share Posted June 24, 2017 The crossover pipe is on top of the engine, under the intake manifold. The upper radiator hose connects to it. Similar to illustration below, #12. The lower pipe rusts from the exhaust heat. "They all do that" after a few years, so no need to worry, just keep an eye on it. My lower pipe has big chunks of rust flaking off - not just surface rust. Thanks for clarifying which pipe was which. Link to comment Share on other sites More sharing options...
apexi Posted June 25, 2017 Share Posted June 25, 2017 I regret buying aftermarket upper and lower radiator hoses, I think I tried Gates and one other brand. The OE spring clamps just barely didn't fit. So I had to spend extra money on fancy hose clamps (Napa constant tension) that I still had to tweak a number of times until they didn't leak after the weather got cold... Link to comment Share on other sites More sharing options...
1-3-2-4 Posted June 25, 2017 Share Posted June 25, 2017 Im doing the same while I have the engine sitting in my bedroom all of the hoses that were PCV had turned hard as a rock and one of the hoses in the back I have to check what it is it snapped off I pretty much got all the hoses from the dealer but the radiator upper and lower hoses my turbo coolant hose was very soft too so I got a new one as well it sucks pricewise but at least I will have piece of mind. Link to comment Share on other sites More sharing options...
devobuzz Posted June 26, 2017 Author Share Posted June 26, 2017 I regret buying aftermarket upper and lower radiator hoses, I think I tried Gates and one other brand. The OE spring clamps just barely didn't fit. So I had to spend extra money on fancy hose clamps (Napa constant tension) that I still had to tweak a number of times until they didn't leak after the weather got cold... Uh oh I just got some Dayco hoses. Why didn't the spring clamps fit. Were they too small or too big for the hoses? Link to comment Share on other sites More sharing options...
apexi Posted June 26, 2017 Share Posted June 26, 2017 Too small, by literally a few mm's. You might get lucky, I don't remember if dayco was a brand I tried. Link to comment Share on other sites More sharing options...
Max Capacity Posted June 29, 2017 Share Posted June 29, 2017 I seem to recall the issue when I replaced the OEM hoses during my engine rebuild, the new hoses were fatter, just use a screw type hose clamp like we have been using for decades. Much easier to work with. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
