2006 Subaru Legacy GT
i have a turbo on my car that is broken, 166000 miles, they say its $1900ish to fix. my question is if i fix it what is the likely hood that more major problems wont occur? Has anyone had to get the turbo replaced and how does the car run good after? The car runs great still with the turbo broken it just doesn't accelerate very good.
could you also honestly answer this question...Do i fix the car or buy a new one?
Thank you in advance!
Erik
Erik
Based on the first quote above, I'd say the chances of your car being properly broken are quite high. A full engine rebuild will run between 3k-8k, depending on your level of involvement. If you don't have that kind of coin, and or time, to spend, then sell the car ASAP and cut your losses.
Further, if you think your LGT still drives great with a broken turbo, I'd re-evaluate your choice in transportation. Maybe consider something intended to be naturally aspirated.
LW's spec. B / YT / IG
Erik
Welcome to the forum, you just posted this in the wrong forum. Try the 4th Gen below and read the sticky's at top of t he Tech Forum. All the answers are here.
Read a little and tell us how good you are with tools.
Most of us have been where you are.
Engine Build - Click Here
Moved to 4h Gen turbo powertrain sub-forum.
OP, welcome to the site and good luck with your issue.
