Whopper Posted April 25, 2017 Share Posted April 25, 2017 So I cant find any of the pre molded hoses for the valve covers. No one has them anymore. What should I use instead? I need hose number 9, 8, 15, 10. http://parts.subaru.com/images/parts/subaru/fullsize/B10_082B0046.png Can I just use something like this Oil Hose 3/8 Any other ideas? Link to comment Share on other sites More sharing options...
awfulwaffle Posted April 25, 2017 Share Posted April 25, 2017 I just did on my 05 LGT simply because I didn't realize I'd need to replace one of the molded hoses, and had to drive 400 miles that night. Worked fine, though routing was a little tricky. Link to comment Share on other sites More sharing options...
Whopper Posted April 26, 2017 Author Share Posted April 26, 2017 I just did on my 05 LGT simply because I didn't realize I'd need to replace one of the molded hoses, and had to drive 400 miles that night. Worked fine, though routing was a little tricky. So you just used some of the oil hose line? Link to comment Share on other sites More sharing options...
Brighton96 Posted April 26, 2017 Share Posted April 26, 2017 I just went to the auto parts store and bought like 6ft of 3/8 (maybe?) braided core hose and routed it the way I wanted to, it let me getting a bit neater looking engine bay that way Link to comment Share on other sites More sharing options...
Whopper Posted April 26, 2017 Author Share Posted April 26, 2017 I just went to the auto parts store and bought like 6ft of 3/8 (maybe?) braided core hose and routed it the way I wanted to, it let me getting a bit neater looking engine bay that way So it was easy to bend so you can route it? Link to comment Share on other sites More sharing options...
Brighton96 Posted April 26, 2017 Share Posted April 26, 2017 Yeah, the hose is fairly flexible, but you can't do much more than 60-70 degree bends without creating a kink in the hose. It's only $1.50 a foot ish and in my opinion, I'd rather have non molded stuff so that I can route it the way I want. I was going to route mine into a catch can and then into the intake, which would be tricky to do with molded ones. Link to comment Share on other sites More sharing options...
doublechaz Posted April 26, 2017 Share Posted April 26, 2017 Yep. Just get oil safe hose for oil stuff. Fuel safe for fuel stuff. etc... Link to comment Share on other sites More sharing options...
Whopper Posted April 26, 2017 Author Share Posted April 26, 2017 Can anyone recommend a hose online? I can't get anything from the auto parts store around here. Any recommendations? Link to comment Share on other sites More sharing options...
Whopper Posted April 26, 2017 Author Share Posted April 26, 2017 Will this work https://www.amazon.com/dp/B01MTX6XHX/ref=cm_sw_r_cp_apa_HOoazbJG33K5T Link to comment Share on other sites More sharing options...
awfulwaffle Posted April 26, 2017 Share Posted April 26, 2017 Yep. Learned a neat trick about kinking the hose in the process: you can use a moderately tight hose clamp at the kink to force the hose to retain its shape. Allowed me to make the 90 degree bend into the block I needed. Link to comment Share on other sites More sharing options...
Whopper Posted April 26, 2017 Author Share Posted April 26, 2017 https://www.amazon.com/gp/product/B004XONNTE/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1 Just ordered that I hope it is correct. Link to comment Share on other sites More sharing options...
Brighton96 Posted April 26, 2017 Share Posted April 26, 2017 That should be the right stuff, but I'm like 85% sure I used 3/8th hose when I did mine Link to comment Share on other sites More sharing options...
Whopper Posted April 27, 2017 Author Share Posted April 27, 2017 That should be the right stuff, but I'm like 85% sure I used 3/8th hose when I did mine Yes that was id 3/8 and you scared me so I went and cancelled it but didnt need to. Link to comment Share on other sites More sharing options...
Whopper Posted April 27, 2017 Author Share Posted April 27, 2017 Im also pretty sure the size needed is 3/8 because the valve cover is 1/2 so I should get a little smaller correct. Link to comment Share on other sites More sharing options...
Brighton96 Posted April 27, 2017 Share Posted April 27, 2017 Yes that was id 3/8 and you scared me so I went and cancelled it but didnt need to. Whoops, didn't mean to scare you. The only ones it could be are 3/8 or 5/16, and I don't have my car here to check for you :/ Link to comment Share on other sites More sharing options...
Whopper Posted April 27, 2017 Author Share Posted April 27, 2017 Yea I think its 3/8. Ill tell you if it works or not. Link to comment Share on other sites More sharing options...
Whopper Posted April 29, 2017 Author Share Posted April 29, 2017 Ok so I got the 3/8 hose and it seems like it will fit on it ok but its just a little to tight to get on. It will go on about 1/4 an inch and then I cant push it on any further. Please help Link to comment Share on other sites More sharing options...
awfulwaffle Posted April 29, 2017 Share Posted April 29, 2017 Have you tried putting rubbing alcohol on the fitting you're trying to slip the hose on? Helps it slip on and then evaporates. Link to comment Share on other sites More sharing options...
Whopper Posted April 29, 2017 Author Share Posted April 29, 2017 So I am able to get the hoses on now but I think I will have to remove the entire air intake manifold to I can remove one of the old dry rotted hoses. Hose number 10. http://www.surrealmirage.com/vrg3/vacuum/ej22t_pcv.gif Link to comment Share on other sites More sharing options...
Whopper Posted April 29, 2017 Author Share Posted April 29, 2017 Im so screwed I needed this car to be running last week. Any ideas or should I pussy out and call the mechanic and shell out several hundred? Link to comment Share on other sites More sharing options...
awfulwaffle Posted April 29, 2017 Share Posted April 29, 2017 Are you saying you're having trouble separating hose 10 from hard line 14? I'd get a good set of hose cutters or a sharp blade and cut it off, if that's the case. Then split stub that's left attached to the hardline down its length. You can also buy hose pliers at Harbor Freight for like 15 bucks. Pretty much long needle nose with the tips bent to let you grab various diameter hoses pretty easily. Make getting old crusty hoses off way less of a pain in the ass. http://www.harborfreight.com/3-piece-long-reach-hose-grip-pliers-37909.html Link to comment Share on other sites More sharing options...
Brighton96 Posted April 30, 2017 Share Posted April 30, 2017 I just use wd-40 or some other kind of lube like that to get hoses onto where they need to go. If that doesn't work then I progressively stretch the hose by gradually pushing needle nose pliers into the hose, the taper of the pliers with carefully stretch the hose until I can get it to fit. Link to comment Share on other sites More sharing options...
Whopper Posted April 30, 2017 Author Share Posted April 30, 2017 NO I mean I physically cant get to it because the intake manifold sits on top of it. Link to comment Share on other sites More sharing options...
Brighton96 Posted April 30, 2017 Share Posted April 30, 2017 Oh I misunderstood, What you may have to do it unbolt the intake manifold from the engine, which is just 4 bolts on each side of the engine and then just lift it up and put something under it like a chunk of wood to keep it up and out of the way. I don't think you have to disconnect any other wires, cables or hoses in order to do this since the intake will only move 3-5 inches upward. It's been a while since I did that so you may have to remove some little stuff but I don't know what Link to comment Share on other sites More sharing options...
Whopper Posted April 30, 2017 Author Share Posted April 30, 2017 Yea I think Im going to bitch out and take it to the local subaru "certified" shop and have them replace all the dry rotted lines(everything is dry rot) and reconnect all the valve cover lines and stuff. I need this car running soon so I cant risk me trying to do it all. Link to comment Share on other sites More sharing options...
