SirJ Posted April 19, 2017 Share Posted April 19, 2017 Hello, I've started to have a problem for about a week with my 2006 legacy gt (manual transmission). When I try to accelerate the car takes it's time and accelerates slow. Just this morning heading to college I started to reverse and after a short while it stops. It doesn't turn off it just stops reversing. Even when I give it gas. All the fluids are topped off, there are no weird sounds and no check engine light turns on. Please help. Link to comment Share on other sites More sharing options...
Max Capacity Posted April 19, 2017 Share Posted April 19, 2017 How old is the clutch ? has it ever been replaced ? Do you know what slipping clutch feels like ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
relative4 Posted April 19, 2017 Share Posted April 19, 2017 Is your engine turning high RPMs and the transmission & wheels not turning to match? Do experience a sort of slipping sensation as you let out the clutch? If so, your clutch is dead. A bad front differential can have similar symptoms but is much less likely. Link to comment Share on other sites More sharing options...
SirJ Posted April 19, 2017 Author Share Posted April 19, 2017 Could be the clutch. I don't feel anything out of the ordinary just that the car won't move. It doesn't shake or make any weird noises. When I'm reversing I can't let go of the clutch completely or it stalls. But when I tried this morning it doesn't stall Link to comment Share on other sites More sharing options...
DonnyJagaru Posted April 19, 2017 Share Posted April 19, 2017 I had an old car do this and it was bent shifter forks from me slamming it into gears really, really hard because I perceived that my life sucked at the time. Link to comment Share on other sites More sharing options...
JustCallMeNick Posted April 19, 2017 Share Posted April 19, 2017 slamming it into gears really, really hard because I perceived that my life sucked at the time. Dang, been there. Link to comment Share on other sites More sharing options...
