extinqt Posted April 10, 2017 Share Posted April 10, 2017 I was driving my 08 legacy gt today and I got to a red light and there was smoke coming from the hood/hood scoop. It smelled like burning rubber! Any suggestions on what it is? Thanks! Also, when I popped the hood, the coolant level was almost to the cap! Link to comment Share on other sites More sharing options...
Sboarderk03 Posted April 10, 2017 Share Posted April 10, 2017 I don't know about the coolant but a common problem comes from a small oil leak out of the vcg. Either directly related to the gasket itself or the little plastic half moon pieces that go along the gasket. A small amount of oil drips onto the up pipe causing smoke usually from the pass side. Link to comment Share on other sites More sharing options...
extinqt Posted April 10, 2017 Author Share Posted April 10, 2017 Thanks for the suggestion. I will check it tomorrow! Link to comment Share on other sites More sharing options...
cseagle08 Posted April 10, 2017 Share Posted April 10, 2017 I'd say check condition of the belts Link to comment Share on other sites More sharing options...
LatentWagen Posted April 10, 2017 Share Posted April 10, 2017 +1 on the belts. A burning rubber smell should be telling, could be any of a number of hoses, too. Coolant and oil are very specific smells when they burn. If not the belts or hoses, I'd check the CV boots (especially the pass. side, next to the downpipe). Axle grease has a funny smell for the uninitiated. LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
extinqt Posted April 10, 2017 Author Share Posted April 10, 2017 +1 on the belts. A burning rubber smell should be telling, could be any of a number of hoses, too. Coolant and oil are very specific smells when they burn. If not the belts or hoses, I'd check the CV boots (especially the pass. side, next to the downpipe). Axle grease has a funny smell for the uninitiated. The passenger side cv boot is ripped. There is grease everywhere! Looks like some got onto the downpipe, would that cause the smoke? Link to comment Share on other sites More sharing options...
MilesA Posted April 10, 2017 Share Posted April 10, 2017 The passenger side cv boot is ripped. There is grease everywhere! Looks like some got onto the downpipe, would that cause the smoke? Yes, it's very common. Link to comment Share on other sites More sharing options...
Dishwasher Posted April 10, 2017 Share Posted April 10, 2017 +1 for passenger side cv boot throwing grease on your down pipe. Brought to you by Pfizer Link to comment Share on other sites More sharing options...
whitetiger Posted April 10, 2017 Share Posted April 10, 2017 passenger cv boot, or leaky turbo oil return hose/gasket Link to comment Share on other sites More sharing options...
nightmonkeygt Posted April 10, 2017 Share Posted April 10, 2017 When my valve cover gasket was leaking, the oil was dripping on the exhaust which caused smoke to come from the hood scope. Link to comment Share on other sites More sharing options...
LatentWagen Posted April 10, 2017 Share Posted April 10, 2017 The passenger side cv boot is ripped. There is grease everywhere! Looks like some got onto the downpipe, would that cause the smoke? Glad you got it figured out. Welcome to turbo Subaru ownership Heat from the downpipe causes the passenger side CV boot to wear fastest. Then it cracks, rips, and spews grease everywhere. As usual, some landed on the downpipe, hence your smokeshow. Replace the boot quickly, and you'll likely be able to save the axle. If you do need to replace the whole axle, don't buy an aftermarket one. Instead go with OEM, or OEM-remanufactured (Subaru does it, and it saves $ over new). LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
MilesA Posted April 11, 2017 Share Posted April 11, 2017 Replace the boot quickly, and you'll likely be able to save the axle. If you do need to replace the whole axle, don't buy an aftermarket one. Instead go with OEM, or OEM-remanufactured (Subaru does it, and it saves $ over new).Very good advice. Nowadays, a lot of mechanics will just swap parts. Sometimes, the parts they put in are not as good as what you already have. See if you can just replace the boot. Just don't let dirt or grit get into that joint and it should be fine. Link to comment Share on other sites More sharing options...
extinqt Posted April 11, 2017 Author Share Posted April 11, 2017 Will do! I will replace it on Thursday, for the time being I'm driving the good old Civic, haha! Link to comment Share on other sites More sharing options...
Max Capacity Posted April 11, 2017 Share Posted April 11, 2017 Nothing wrong with an old civic, it serves its purpose, doesn't it... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
extinqt Posted April 11, 2017 Author Share Posted April 11, 2017 It definitely serves its purpose! Link to comment Share on other sites More sharing options...
