dule999 Posted March 30, 2017 Share Posted March 30, 2017 hi guys i have 2008 legacy lgt limited starts. smoking after long idle like if i leave the car on and idling for about 30-40 min then it starts to smoke any ideas why i took the dp off turbo is bone dry from the exhaust side took the intercooler and turbo inlet pipe to see if the intake side is also good brand new tomei uel with all new turbo gaskets and headers gaskets also pcv valve replaced new spark plugs i dont know what else to check could it be the ewg... Link to comment Share on other sites More sharing options...
JustCallMeNick Posted March 30, 2017 Share Posted March 30, 2017 Valve cover gaskets leak on these cars. Maybe it's dripping onto your new headers or something? Do you normally let your car idle for 40 minutes? Is it smoking out the exhaust in the rear? Or smoking under the hood? Link to comment Share on other sites More sharing options...
DonnyJagaru Posted March 31, 2017 Share Posted March 31, 2017 Oil filter not tight enough. Rustproofing melting onto exhaust. Link to comment Share on other sites More sharing options...
Max Capacity Posted March 31, 2017 Share Posted March 31, 2017 Why on earth would you idle the car for that long. Its not good for this style engine. Horizontal pistons. Your putting so much heat under the hood, things are going to get really hot. Lack of air flow from a moving car. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
DonnyJagaru Posted April 3, 2017 Share Posted April 3, 2017 Is there any truth that horizontally opposed engines wear the cylinders out more due to gravity? I was reading about the 1932 Ford V8 (first year) and detractors back in the 1930's were claiming the same thing with V8 engines, as compared to inline engines. So I wonder if this is an old wives tale that refused to die? Link to comment Share on other sites More sharing options...
Max Capacity Posted April 3, 2017 Share Posted April 3, 2017 Think about how the piston sit's when the engine is not running...either way, unless your a cop idling waiting to catch a speeder, why would you idle for that long ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
