Ace37 Posted February 20, 2017 Share Posted February 20, 2017 Is it possible? Yes i know its meant for the intercooler and the N/A doesnt have it but would it fit? Call it ricey if you want but i love the look of it but couldnt find a GT and couldnt afford one. Im not worried about water getting in as i already have that worked out. Also are the hoods for the outback and legacy gt interchangeable? One parts website lists them together and marks them as interchangeable. Link to comment Share on other sites More sharing options...
I Donated Too sigmafour Posted February 20, 2017 I Donated Too Share Posted February 20, 2017 yep. You can if you really want to. Link to comment Share on other sites More sharing options...
amm203 Posted February 20, 2017 Share Posted February 20, 2017 You might get lucky and find someone who went FMIC and wants to swap with you if you have the same color. I believe 08-09 hoods are interchangeable between N/A & GTs. Your best bet is probably here: http://www.car-part.com/ You can search for 2008 Legacy hoods with scoops across a national database of junkyards. The junkyard guys don't tend to ship so you have to hope there's a hood that matches your color at a reasonable distance from your zip. Edit: Noticed you're in Savannah. I ran a search for you and closest junkyard with scooped Legacy hoods is about 200 miles from you. Link to comment Share on other sites More sharing options...
Ace37 Posted February 20, 2017 Author Share Posted February 20, 2017 You might get lucky and find someone who went FMIC and wants to swap with you if you have the same color. I believe 08-09 hoods are interchangeable between N/A & GTs. Your best bet is probably here: http://www.car-part.com/ You can search for 2008 Legacy hoods with scoops across a national database of junkyards. The junkyard guys don't tend to ship so you have to hope there's a hood that matches your color at a reasonable distance from your zip. Edit: Noticed you're in Savannah. I ran a search for you and closest junkyard with scooped Legacy hoods is about 200 miles from you. Mhmm okayy thanks and where was this hood? I might go pick it up Link to comment Share on other sites More sharing options...
amm203 Posted February 20, 2017 Share Posted February 20, 2017 If you use that website; Choose your model, year, and throw in your zip. Be sure to have "Hood" chosen under "Select Part" and be sure to choose "exc. Outback; hood scoop" option after you hit "Search". Then you can sort by mileage! Link to comment Share on other sites More sharing options...
JustCallMeNick Posted February 20, 2017 Share Posted February 20, 2017 I guess all the non-car people probably think it's just for looks anyway. And arguably it's not any more ricey than my spiffy (Chinese) gold Konig rims. Link to comment Share on other sites More sharing options...
Ace37 Posted February 20, 2017 Author Share Posted February 20, 2017 One can look at it as having some form of functionality since is does kind of let in more air per-se but just blows it over the engine and not actually cooling it from the inside Link to comment Share on other sites More sharing options...
Ace37 Posted February 20, 2017 Author Share Posted February 20, 2017 Also just asking, but should i decide to turbo this model would i have to get the engine swapped also or just turbo, intercooler, blowoff, etc like standard cars? Link to comment Share on other sites More sharing options...
CapnJack Posted February 20, 2017 Share Posted February 20, 2017 They do make a turbo kit for your car and there was one for sale in the classifieds recently, but don't know if it still is. Otherwise you can buy new as well. http://legacygt.com/forums/showthread.php/socal-avo-turbo-kit-2-5i-many-extras-245943.html?t=245943&highlight=avo+turbo However, if you are looking for GT performance, you can still swap the engine, transmission, front suspension, ECU, etc, etc, etc. It is a very time consuming and expensive process that many will tell you to "just trade in your NA and buy a turbo version". It's a much less expensive route and will lend you with a more reliable car in the end.(compared to swapping the parts) Link to comment Share on other sites More sharing options...
Ace37 Posted February 20, 2017 Author Share Posted February 20, 2017 They do make a turbo kit for your car and there was one for sale in the classifieds recently, but don't know if it still is. Otherwise you can buy new as well. http://legacygt.com/forums/showthread.php/socal-avo-turbo-kit-2-5i-many-extras-245943.html?t=245943&highlight=avo+turbo However, if you are looking for GT performance, you can still swap the engine, transmission, front suspension, ECU, etc, etc, etc. It is a very time consuming and expensive process that many will tell you to "just trade in your NA and buy a turbo version". It's a much less expensive route and will lend you with a more reliable car in the end.(compared to swapping the parts) Yea probably not doing a full swap because sounds very time consuming and expensive lol and being In the guard and full time college student doesn't give me a lot of time. Probably do the suspension but honestly I wanna drop it maybe 2-2.5in. Thanks for the links Link to comment Share on other sites More sharing options...
Ace37 Posted February 21, 2017 Author Share Posted February 21, 2017 Anyone know if a SRI (short ram intake) or CAI would work on this car? Ive heard mixed opinions but normally its the very first thing i do Link to comment Share on other sites More sharing options...
JustCallMeNick Posted February 21, 2017 Share Posted February 21, 2017 Even the moderately modified GT's on here run the stock intake. Usually intake requires time on the turbo car but I'm not sure about the non turbo models. The danger would be running lean which makes stuff hot and can do damage. Probably won't make a difference on a NA? Don't quote me... Link to comment Share on other sites More sharing options...
The 2Fiver Posted February 21, 2017 Share Posted February 21, 2017 http://legacygt.com/forums/showthread.php/avo-turbo-kit-1000-miles-later-162583.html Here's a successful AVO turbo kit on a 2.5i. It is easier than a motor swap but not cost effective if you're paying a shop to install it. This would be one you would want to tackle on your own and get tuned via opensource. A short ram intake and GT hood would be money and time wasted. You won't be fooling anyone when the sluggish acceleration of the NA 2.5i holds you back. Dumping the car 2" is very low. I was 1.5" on coils and while it was firm around corners and less squatty, the entry level coilovers were too harsh. You'll have to buy wider wheels too because going low low low on stock wheels will look silly. The 2.5i isn't a great candidate for a money pit. Link to comment Share on other sites More sharing options...
Ace37 Posted February 21, 2017 Author Share Posted February 21, 2017 http://legacygt.com/forums/showthread.php/avo-turbo-kit-1000-miles-later-162583.html Here's a successful AVO turbo kit on a 2.5i. It is easier than a motor swap but not cost effective if you're paying a shop to install it. This would be one you would want to tackle on your own and get tuned via opensource. A short ram intake and GT hood would be money and time wasted. You won't be fooling anyone when the sluggish acceleration of the NA 2.5i holds you back. Dumping the car 2" is very low. I was 1.5" on coils and while it was firm around corners and less squatty, the entry level coilovers were too harsh. You'll have to buy wider wheels too because going low low low on stock wheels will look silly. The 2.5i isn't a great candidate for a money pit. Yea I plan on wider wheels also. I had my CL Type-S dropped and my Maxima and have always loved the look. Link to comment Share on other sites More sharing options...
