RI spec b Posted February 18, 2017 Share Posted February 18, 2017 I have a 07 spec b I'm trying to install a dom 1.5xtr I also got a killer b headers with the up pipe. I used the vehicle clamp to clamp the header to the up pipe but I can't get the turbo to line up and I can only get one out of 3 bolts into the turbo to the up pipe. So removed it and bolted the turbo to the up pipe out side the car but then I cant gethe the up pipe below the turbo bracket. Do I remove the turbo bracket and not use that? Also the oil line th at is supplied that is flexible were does that go into see the line that use to go to the turbo I followed it to the end of line it goes to a banjo bolt that is next the fuel lines on passengerside. Link to comment Share on other sites More sharing options...
MTBwrench Posted February 20, 2017 Share Posted February 20, 2017 Okay, first of all, nobody is going to respond to this(except me I guess). Use some grammar and punctuation. Not being a jerk, but this is SO hard to read! Oh boy... I'm not familiar with installing that turbo or those headers, but it's all stock location isn't it? Only issue should be clocking the up-pipe properly if KillerB uses a v-clamp. Don't take this the wrong way at all, but perhaps if there's so many issues have a professional do the work? MTBwrench's Stage 3 5EAT #racewagon 266awhp/255awtq @17.5psi, Tuned By Graham of Boosted Performance Everyone knows what I taste like. Link to comment Share on other sites More sharing options...
fahr_side Posted February 20, 2017 Share Posted February 20, 2017 It is a tough squeeze. You may need to grind the transmission bell housing a little to squeeze it in there. Deleting the TGVs may be necessary on the older cars. If you got the 3" inlet version you may need to use a hard inlet pipe. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
rapture Posted February 20, 2017 Share Posted February 20, 2017 some pricey parts.... u can afford a good tech/mech.... Link to comment Share on other sites More sharing options...
RI spec b Posted February 20, 2017 Author Share Posted February 20, 2017 I got it in I didn't realize that the old up pipe had studs in it. I installed new studs and it went right in np. I do wanna say I'd suggest putting the inlet hose on before the turbo is in all the way. Link to comment Share on other sites More sharing options...
Rhitter Posted February 20, 2017 Share Posted February 20, 2017 some pricey parts.... u can afford a good tech/mech.... This doesn't make sense. I can afford pricey parts because I do the work myself (at least if the engine is blown up). Plus, installing it yourself can be half the fun (if not more) @ OP glad you figured it out. Was the problem you were trying to bolt the turbo to the up-pipe and with bolts (instead of studs) you weren't able to get everything attached and lined up? My OBXT build Link to comment Share on other sites More sharing options...
RI spec b Posted February 21, 2017 Author Share Posted February 21, 2017 I dont understand why people have to insult me. I come and asked a question hoping I could get some help. I am not a mechanic but I do work on cars alot. Also my friend that has been giving me a hand he is a ase certified mechanic. I don't work on these cars everyday. I ran into a snag and you guys are telling me I shouldn't be installing parts on my car. At the same time I've installed a fuel pump, injectors a iag aos, timing belt and a cam seal. So I get stuck putting one part in and you guys have to insult me. I was using bolts, I did go to the dealership to get the studs but they said they only come on the up pipe so I decided to use bolts. But it would not line up so I went out and got aftermarket studs and it slid right on with no effort. Link to comment Share on other sites More sharing options...
Max Capacity Posted February 21, 2017 Share Posted February 21, 2017 FWIW, I bolt the turbo to the up pipe, makes things easier. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
RI spec b Posted February 21, 2017 Author Share Posted February 21, 2017 I put bolts on the back side were the hot side is then the side one is a tight fit even with 14 mm nut size so I used a studded there and on the front side. Link to comment Share on other sites More sharing options...
MTBwrench Posted February 21, 2017 Share Posted February 21, 2017 I dont understand why people have to insult me. I come and asked a question hoping I could get some help. I am not a mechanic but I do work on cars alot. Also my friend that has been giving me a hand he is a ase certified mechanic. I don't work on these cars everyday. I ran into a snag and you guys are telling me I shouldn't be installing parts on my car. At the same time I've installed a fuel pump, injectors a iag aos, timing belt and a cam seal. So I get stuck putting one part in and you guys have to insult me. I was using bolts, I did go to the dealership to get the studs but they said they only come on the up pipe so I decided to use bolts. But it would not line up so I went out and got aftermarket studs and it slid right on with no effort. We're not insulting you, lighten up buttercup. We'd just hate to see someone make a mistake with parts as nice as that. I'll agree with Rhitter on the "you can afford a mechanic" aspect, because I sure as hell can't! MTBwrench's Stage 3 5EAT #racewagon 266awhp/255awtq @17.5psi, Tuned By Graham of Boosted Performance Everyone knows what I taste like. Link to comment Share on other sites More sharing options...
RI spec b Posted February 21, 2017 Author Share Posted February 21, 2017 I could of had the tuner install everything but I enjoy doing work on cars even if it's a headache sometimes. Also if I have a problem in future I will know how everything goes together and works. Link to comment Share on other sites More sharing options...
Rhitter Posted February 21, 2017 Share Posted February 21, 2017 Dude, one person, only one, said you should have paid someone to install it for you. Just ignore that person and let it go. My OBXT build Link to comment Share on other sites More sharing options...
fahr_side Posted February 22, 2017 Share Posted February 22, 2017 just block that person and let it go. ftfy Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
tocinoman25 Posted February 24, 2017 Share Posted February 24, 2017 pics of the finished installation or youre lying lol... glad you got it all together...subbed for some plots and dyno video and street pulls in mexico... Follow me on IG @chefodiycarguy and @chefo.soriano Link to comment Share on other sites More sharing options...
rapture Posted February 25, 2017 Share Posted February 25, 2017 Man U are sensitive bruh You basically have the most expensive shit Your new So yeah i was breakin ur balls a lil Relax Or yeah block I could care less lol Link to comment Share on other sites More sharing options...
gimpydingo Posted February 27, 2017 Share Posted February 27, 2017 Man U are sensitive bruh You basically have the most expensive shit Your new So yeah i was breakin ur balls a lil Relax Or yeah block I couldn't care less lol Fify Link to comment Share on other sites More sharing options...
