splifflacquer Posted February 18, 2017 Share Posted February 18, 2017 Car has been running lean since I had a shop in Denver install a new turbo inlet. Got busy and just rode my motorcycle for a while. Dug into it tonight to find a big fat leak somewhere around the turbo inlet. Also found a sensor (don't know what to) dangling and one female harness empty. It's now the weekend and they're not open. What are these things? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
CapnJack Posted February 18, 2017 Share Posted February 18, 2017 It's part of the PCV (positive crankcase ventilation) system. I've seen them like that when someone deletes it and installs an air oil separator. Link to comment Share on other sites More sharing options...
Gex Posted February 18, 2017 Share Posted February 18, 2017 +1 but also. If you installed a Perrin or other aftermarket inlet than it is removed (Pcv still should have a line into the inlet, that part is just removed. Instructions for the inlet say to remove the prong and plug it back into the sensor than just tuck the connector under the manifold. It shouldn't throw a cel unplugged. Link to comment Share on other sites More sharing options...
Underdog Posted February 18, 2017 Share Posted February 18, 2017 One on the shock tower is for the EGT sensor. You can do the resistor mod and delete the sensor. Or if you still have the sensor in your uppipe you can just plug it back in. The Crimson Dynamo Link to comment Share on other sites More sharing options...
MilesA Posted February 18, 2017 Share Posted February 18, 2017 +1 do the resistor mod and tape that connector on the shock tower. Do you still have an EGT sensor on the uppipe? Probably not. The PCV wiring is really not much, just a continuity check, basically, which many people remove without real consequences. Link to comment Share on other sites More sharing options...
splifflacquer Posted February 18, 2017 Author Share Posted February 18, 2017 Thank you everyone! I haven't thrown a CEL except one the other day telling me that bank 1 was too lean... I imagine that's due to a boost leak around the turbo inlet (it is indeed a Perrin). It's light again outside so Ima go check it out. Thanks again my dudes Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
