rbrtclk Posted January 6, 2017 Share Posted January 6, 2017 Does anyone know if there is an aftermarket kit that plugs into the audio unit of a legacy (2014) that does not have navigation? My car does not have navigation. I am looking for a rear backup kit that would play through my audio unit. Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted January 7, 2017 Share Posted January 7, 2017 here is the wiring diagram so you can connect it http://jdmfsm.info/Auto/Japan/Subaru/Legacy%20Outback/2014/USDM%20Legacy%20FSM%202014%20(BM-BR)/7%20WIRING%20SYSTEM%20SECTION/40%20Rearview%20Camera%20System.pdf Link to comment Share on other sites More sharing options...
dgoodhue Posted January 7, 2017 Share Posted January 7, 2017 If you have the premium 2014 that doesn't have back up camera (4.3" screen), most of the wiring should already be in the car. I think you would just need to ground one of the radio input for the camera and add a camera and harness in the trunk. The interior/audio section the forum has some posts about adding a camera to the various radio's. Link to comment Share on other sites More sharing options...
Picky1 Posted May 5, 2017 Share Posted May 5, 2017 I have a 2012 Premium and I really want to add a back-up camera to the car. I saw in the local Subaru forum the radio pictured below, does this unit support a backup camera? and is it compatible with my car? Link to comment Share on other sites More sharing options...
jojorios Posted May 5, 2017 Share Posted May 5, 2017 http://legacygt.com/forums/showthread.php/rear-camera-input-5th-gen-hus-w-4-3-screen-218335.html Svxdc is the person you want to talk to. He sold me the wire needed to setup the camera. I'm just not sure how active he is anymore. He was very tough to get in contact with in the past. Sent from my SM-G935F using Tapatalk Link to comment Share on other sites More sharing options...
FLlegacy Posted May 5, 2017 Share Posted May 5, 2017 He is kind of on and off with the forum. Sent from my SAMSUNG-SM-G920A using Tapatalk Link to comment Share on other sites More sharing options...
capttris Posted May 5, 2017 Share Posted May 5, 2017 I looked into this a few years ago. Same thing with my car. Limited NO NAV. And I have the homelink mirror. There is a coax cable up in the headliner and it apparently runs back to the trunk. But I was never able to figure out the installation of an OEM Subaru rear camera to project onto either: the stereo screen OR apparently there is a screen built into the homelink mirror. Never figured it out... Link to comment Share on other sites More sharing options...
DrD123 Posted May 5, 2017 Share Posted May 5, 2017 the cable in the headliner is probably for the satellite antenna. For the stereo, you go through the regular wiring harness (not a separate coax) - lots of info in this thread http://legacygt.com/forums/showthread.php/rear-camera-input-5th-gen-hus-w-4-3-screen-218335.html Link to comment Share on other sites More sharing options...
capttris Posted May 7, 2017 Share Posted May 7, 2017 thanks. The coax cable ends with a coax fitting that is not plugged into anything, up in the headliner above the front map lights (I had removed this to get 12V power for a radar detector and discovered that coax cable not connected to anything up there) And my satellite radio works fine (not that I use it) Link to comment Share on other sites More sharing options...
dgoodhue Posted May 7, 2017 Share Posted May 7, 2017 The cable in the headliner could wiring be for a backup camera. Some 2013 Outbacks Premiums had a backup camera in the rear view mirror. Link to comment Share on other sites More sharing options...
Hillside Joe Posted May 8, 2017 Share Posted May 8, 2017 The cable in the headliner could wiring be for a backup camera. Some 2013 Outbacks Premiums had a backup camera in the rear view mirror. My 2013 Legacy 26i Premium is equipped with the back-up camera in the rear view mirror. Although about 1 time in every 10 the image it presents is upside - down! Link to comment Share on other sites More sharing options...
bloodwingg2 Posted May 8, 2017 Share Posted May 8, 2017 Or, get an aftermarket dvd double din and add yourself a rear camera Link to comment Share on other sites More sharing options...
Picky1 Posted May 8, 2017 Share Posted May 8, 2017 Or, get an aftermarket dvd double din and add yourself a rear camera That would be Plan B, as I noted I can get the OEM radio for dirt cheap so I figured I would explore what it would take to install. Also, I have yet to see an after-market radio with a nice flush install on a 5th gen. Another option that I was thinking about was doing a tablet install like they have done in the 4th Gen Legacy...has anyone tried this in a 5th Gen yet? http://legacygt.com/forums/showthread.php/nexus-7-tablet-install-dummies-guide-256557.html Link to comment Share on other sites More sharing options...
EuroVWGTi Posted May 15, 2017 Share Posted May 15, 2017 Anyone know the part numbers for the oem rear camera? The trim, camera, etc Link to comment Share on other sites More sharing options...
Picky1 Posted May 16, 2017 Share Posted May 16, 2017 Subaru Genuine OEM Factory Original CAMERA, Part number: 86267AJ11B. Link to comment Share on other sites More sharing options...
EuroVWGTi Posted May 16, 2017 Share Posted May 16, 2017 That include the trim as well? Link to comment Share on other sites More sharing options...
Picky1 Posted May 16, 2017 Share Posted May 16, 2017 It looks like it does, but it never hurts to ask the guy at the parts place: https://parts.subaruonlineparts.com/oe-subaru/86267aj11b Link to comment Share on other sites More sharing options...
