tonystark0007 Posted November 26, 2016 Share Posted November 26, 2016 just got my short block install and also did the trans sleeve kit after driving it clutch feel different then before now the to engagement point is all the way up before it was more like halfway any suggestion? on this i had install the clutch 3 month prior to the shortblock thanks . Link to comment Share on other sites More sharing options...
rhino6303 Posted November 26, 2016 Share Posted November 26, 2016 just got my short block install and also did the trans sleeve kit after driving it clutch feel different then before now the to engagement point is all the way up before it was more like halfway any suggestion? on this i had install the clutch 3 month prior to the shortblock thanks . What year? On my 05, you can adjust the clutch. In the FSM it is section CL-23. Here is a somewhat shortened summary. Measure from seat to pedal and then again with pedal depressed. The distance should be 5.51". If it is not, your clutch needs adjustment. To adjust, loosen the lock nut above the throttle pedal and turn the rod ccw to shorten or cw to lengthen. After adjusting the rod, you will have to adjust the clutch cruise switch which is above the clutch pedal. The switch should have 0 clearance with the pedal. Here is how to adjust the clutch pedal travel. Link to comment Share on other sites More sharing options...
tonystark0007 Posted November 26, 2016 Author Share Posted November 26, 2016 ill try that. is it suppose to feel less power also Link to comment Share on other sites More sharing options...
Max Capacity Posted November 28, 2016 Share Posted November 28, 2016 Air in the system ??? Did you raise the slave cylinder above the reservoir ? 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Hoojammyflip Posted July 27, 2017 Share Posted July 27, 2017 Thanks Link to comment Share on other sites More sharing options...
