Dr. Photo Posted October 11, 2016 Share Posted October 11, 2016 The system fits and works like a dream. A really loud obnoxious piss everyone in your house off when you hit the panic button dream. Link to comment Share on other sites More sharing options...
RobbieGT Posted October 11, 2016 Share Posted October 11, 2016 Mind posting a video?? Sent from my SM-N920T using Tapatalk Link to comment Share on other sites More sharing options...
The Grey Goose Posted October 11, 2016 Share Posted October 11, 2016 I'm curious about this as well. Got any mounted pics? Link to comment Share on other sites More sharing options...
Dr. Photo Posted October 11, 2016 Author Share Posted October 11, 2016 http://uploads.tapatalk-cdn.com/20161011/1a2c83177534de9183476d6fc3018b3f.jpg A pair of shorts and a pair of sharps. Sent from my SM-N915P using Tapatalk Link to comment Share on other sites More sharing options...
The Grey Goose Posted October 11, 2016 Share Posted October 11, 2016 I like it! I may go this route and paint them black for something a bit more subtle. I had a single pair of hellas on my old car and those things were crazy loud. I couldn't even imagine two pairs. The bracket mounted up fine? Link to comment Share on other sites More sharing options...
Dr. Photo Posted October 11, 2016 Author Share Posted October 11, 2016 I like it! I may go this route and paint them black for something a bit more subtle. I had a single pair of hellas on my old car and those things were crazy loud. I couldn't even imagine two pairs. The bracket mounted up fine? Bracket mounted up easily. Hellas also now come in various colors. Sent from my SM-N915P using Tapatalk Link to comment Share on other sites More sharing options...
The Grey Goose Posted October 11, 2016 Share Posted October 11, 2016 Bracket mounted up easily. Hellas also now come in various colors. Sent from my SM-N915P using Tapatalk Thanks for answering all of my question! One last question. Did the harness they offer work for our car, or did you wire up your own? Link to comment Share on other sites More sharing options...
Dr. Photo Posted October 11, 2016 Author Share Posted October 11, 2016 I bought the Quadzilla harness and it fits right up, I even got to use one of the stock horns, so technically I have 5 horns running. Sent from my SM-N915P using Tapatalk Link to comment Share on other sites More sharing options...
Dr. Photo Posted October 11, 2016 Author Share Posted October 11, 2016 Just for reference, to get both types of horns on the Quadzilla all pieces need to be ordered separately. Sent from my SM-N915P using Tapatalk Link to comment Share on other sites More sharing options...
15LegacyRyan Posted October 13, 2016 Share Posted October 13, 2016 Can you post the link for the wiring that's plug and play no issues. Awhile ago I know guys tried this and they had to make some modifications for it all to work. I'd like to get a set of red ones. Can't stand the stock horn Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
Dr. Photo Posted October 15, 2016 Author Share Posted October 15, 2016 I didn't follow any guides. Just ran plugs in. Seemed like there was only one way to do it. Sent from my SM-N915P using Tapatalk Link to comment Share on other sites More sharing options...
seang86s Posted October 31, 2016 Share Posted October 31, 2016 Is this the harness you used. This is for "most Subaru models": https://subimods.com/subimods-v2-quad-hella-horn-harness-kit-most-subaru-models.html There is another as well for WRX/STI cars. BTW, where did you mount the relay? Link to comment Share on other sites More sharing options...
Dr. Photo Posted October 31, 2016 Author Share Posted October 31, 2016 Yes that's the harness. I mounted the relay right on the middle of the bracket. There should be a screw or nut sticking out right there. Sent from my SM-N915P using Tapatalk Link to comment Share on other sites More sharing options...
seang86s Posted November 14, 2016 Share Posted November 14, 2016 Did you remove the bracket that comes mounted on the back of the hella horns (the 3 inch metal strip)? I'm having a hard time removing that nut off the bolt without marring the finish. How did you do it? Link to comment Share on other sites More sharing options...
Dr. Photo Posted November 15, 2016 Author Share Posted November 15, 2016 Did you remove the bracket that comes mounted on the back of the hella horns (the 3 inch metal strip)? I'm having a hard time removing that nut off the bolt without marring the finish. How did you do it? Impact gun. Link to comment Share on other sites More sharing options...
bfkellogg Posted November 17, 2016 Share Posted November 17, 2016 So I'm gonna try and install tonight or tomorrow. I'm looking at the videos and I'm a little lost where do I plug in the random spade connection? I'm assuming into the factory horn connection but I just wanted to confirm with someone cuz it's gonna be dark when I install. Sent from my SM-N920V using Tapatalk Link to comment Share on other sites More sharing options...
Dr. Photo Posted November 17, 2016 Author Share Posted November 17, 2016 Use factory connections. I used the left side (facing the car not driving) connector if I remember correctly. Technically I am running the supers, the sharps, and the right horn all in perfect cacophony. Sent from my SM-N915P using Tapatalk Link to comment Share on other sites More sharing options...
bfkellogg Posted November 18, 2016 Share Posted November 18, 2016 So unplug factory wiring a insert spade connector. Sent from my SM-N920V using Tapatalk Link to comment Share on other sites More sharing options...
bfkellogg Posted November 18, 2016 Share Posted November 18, 2016 http://uploads.tapatalk-cdn.com/20161118/7091564c9f62996656f5dd07a3f15daf.jpg Also if any of you are trying to save $10 you can fit 4 on a standard bracket easy. Sent from my SM-N920V using Tapatalk Link to comment Share on other sites More sharing options...
bfkellogg Posted November 19, 2016 Share Posted November 19, 2016 Finally got around to installing this morning. Looks and sounds great. http://uploads.tapatalk-cdn.com/20161119/73d09fe097a344d15fc362bf82ee0864.jpg Sent from my SM-N920V using Tapatalk Link to comment Share on other sites More sharing options...
Dr. Photo Posted November 19, 2016 Author Share Posted November 19, 2016 Very nice! Sent from my SM-N915P using Tapatalk Link to comment Share on other sites More sharing options...
leumaskrap Posted November 19, 2016 Share Posted November 19, 2016 Anyone have comparison of the sound? haha Link to comment Share on other sites More sharing options...
PATS4LIFE Posted November 19, 2016 Share Posted November 19, 2016 Finally got around to installing this morning. Looks and sounds great. http://uploads.tapatalk-cdn.com/20161119/73d09fe097a344d15fc362bf82ee0864.jpg Sent from my SM-N920V using Tapatalkdid u just tap it on the stock horn plug?or used a relay? Link to comment Share on other sites More sharing options...
RobbieGT Posted November 19, 2016 Share Posted November 19, 2016 I'm so close to doing either these or a small train horn set up... I just don't want the hassle of an on board air tank. Link to comment Share on other sites More sharing options...
Dr. Photo Posted November 19, 2016 Author Share Posted November 19, 2016 I'm so close to doing either these or a small train horn set up... I just don't want the hassle of an on board air tank. If you want obnoxious, just pair 4 supers and 4 sharps. I'm pretty sure there should be enough room for two Quadzilla setups. Link to comment Share on other sites More sharing options...
