dvinke1 Posted September 28, 2016 Share Posted September 28, 2016 Possible and/or ok to disconnect the fuel supply line at the engine, attach a hose, and cycle the key on and off to pump the gas into a gas can? Just completing a new build, gas has been sitting in the tank for 8mos and I don't want to risk any bad gas on the inital startup. I am pretty sure I only have 2 gallons or less in the tank. Link to comment Share on other sites More sharing options...
magnusonsubie Posted September 29, 2016 Share Posted September 29, 2016 Shouldn't be an issue. Just make sure you aren't going to completely drain your battery. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
Merc6 Posted September 29, 2016 Share Posted September 29, 2016 I'm glad it's only like 2, I believe I have just over half a tank. Wish I drained it that year but was assuming the car was gonna be running in 6 months with stabil treatment. Let us know how it goes. 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
Merc6 Posted September 29, 2016 Share Posted September 29, 2016 There is also this stolt from my own build thread if need be. http://legacygt.com/forums/showpost.php?p=5472140&postcount=91 http://legacygt.com/forums/showpost.php?p=5475120&postcount=95 2005 Satin White Pearl Subaru Legacy 2.5 GT Unlimited 5EAT (Project Car) 2019 Agate Black Ford Explorer XLT 4WD (DD) Link to comment Share on other sites More sharing options...
ehsnils Posted September 29, 2016 Share Posted September 29, 2016 If you only have 2 gallons in the tank just fill it up and it should work fine. Link to comment Share on other sites More sharing options...
rougeben83 Posted September 30, 2016 Share Posted September 30, 2016 pretty sure there's a drain bolt you can unscrew to drain the tank without dropping it... my old Legacy had it on the passenger side behind a little cover. Link to comment Share on other sites More sharing options...
