zero260 Posted July 12, 2016 Share Posted July 12, 2016 I've got a quick question. I recently rebuilt my motor and have a few upgrades done on an 05 OBXT. Is it safe to drive around and break the motor in on a stock tune or do I need to get something done just to break it in. I don't have all my parts I plan on using yet, so I don't want to get a full tune just to get another one after break in and more parts if I don't have to. Heres my list I have done. ej255 bored .020 over 3mm intake spacers tgv flappers removed STI intake swap bigger TMIC(came with car) 18G turbo(came with car, speed daddy maybe, might be replacing) GS up-pipe custom 3in to dual 2.5 exhaust DW D65c pump EBay silcone intake hose Boost guage, no AFR yet Still stock factory air box factory injectors(will be getting 850s) Let me know if I'm an idiot for thinking about using the stock tune, I just want to drive it a bit before having to chase down a tuner and spend a bunch more on parts(need to save up for a bit) Link to comment Share on other sites More sharing options...
08SpecB_DE Posted July 12, 2016 Share Posted July 12, 2016 Do not run a factory tune. If you drive it, believe me, you will end up spending a lot more than you bargained for. Link to comment Share on other sites More sharing options...
solidxsnake Posted July 12, 2016 Share Posted July 12, 2016 I'd recommend getting off the stock tune as well... to be honest, since you're running stock airbox and injectors, I'd drop the cash on a VAGCOM cable (easily under $15-20) and learn the basics of tuning on your own... sure, it's got some learning curve, but really, it's not excessively difficult and you don't need anything more than a laptop (or an android device and BtSsm), some time, and some patience. The amount you'll learn about how the ECU works and how the car operates will help you take care of your car and keep it in good shape. There's plenty of resources on these forums, the RomRaider forums, and on the web in general. Link to comment Share on other sites More sharing options...
utc_pyro Posted July 12, 2016 Share Posted July 12, 2016 At the very least force it into wastegate boost mechanically, but solidxsnake's suggestion is better. You can still have it protuned turned (even on Cobb) later. Link to comment Share on other sites More sharing options...
Tuning Alliance Posted July 13, 2016 Share Posted July 13, 2016 I would advise against it, contact us we can get you setup on a proper etune. -Brian Contact us for all your tuning and performance parts needs! Etuning the legacy community since 2008! Follow us on FACEBOOK | INSTAGRAM [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
