kustomitch Posted June 16, 2016 Share Posted June 16, 2016 So I was going through everything before my tune that was supposed to be today. Changed the oil, checking hoses and stuff. Car has id1000 injectors and a walbro 255. It ran good all week and then I started it up last night and it started stumbling and running terrible. Turned it off and figured there was a vacuum leak or something. Everything looked fine. Got back in and started it. Running bad and noticed I'd lost a quarter tank of gas. Somegow all that fuel is getting pumped into the engine. Drained the oil and pull the plugs today. Oil was full of gas. Exhaust was blowing gas out too. Seems pretty serious and I have no idea what could be going on. Any ideas? Link to comment Share on other sites More sharing options...
Tuning Alliance Posted June 16, 2016 Share Posted June 16, 2016 Sounds like your running way to rich. Washes the rings and goes into the pan. Who tuned your car? Do you have a wideband? -Brian Contact us for all your tuning and performance parts needs! Etuning the legacy community since 2008! Follow us on FACEBOOK | INSTAGRAM [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
kustomitch Posted June 16, 2016 Author Share Posted June 16, 2016 Sounds like your running way to rich. Washes the rings and goes into the pan. Who tuned your car? Do you have a wideband? -Brian It's definitely running rich. I was going for a tune today and then this happened. No wideband yet. It was running ok with no leaks or anything. I put the injectors in last weekend along with all new vacuum lines and turbo inlet. I feel like it's way more than just running rich though. Link to comment Share on other sites More sharing options...
Tuning Alliance Posted June 17, 2016 Share Posted June 17, 2016 Wait, you put different injectors in without being tuned for it? Contact us for all your tuning and performance parts needs! Etuning the legacy community since 2008! Follow us on FACEBOOK | INSTAGRAM [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
jay p Posted June 17, 2016 Share Posted June 17, 2016 If it was running good on the current tune, I would check the fuel pressure regulator. If the diaphragm is ruptured it can put a lot of raw fuel into the engine. Link to comment Share on other sites More sharing options...
kustomitch Posted June 17, 2016 Author Share Posted June 17, 2016 Wait, you put different injectors in without being tuned for it? Yes I put id1000s in over the weekend before my tune which was supposed to be yesterday. I ran it to make sure there were no leaks or anything and it was ok. Link to comment Share on other sites More sharing options...
solidxsnake Posted June 19, 2016 Share Posted June 19, 2016 Yes I put id1000s in over the weekend before my tune which was supposed to be yesterday. I ran it to make sure there were no leaks or anything and it was ok. Well... that's your problem You need to adjust your fueling if you change your injectors. Link to comment Share on other sites More sharing options...
Tuning Alliance Posted June 19, 2016 Share Posted June 19, 2016 Yes I put id1000s in over the weekend before my tune which was supposed to be yesterday. I ran it to make sure there were no leaks or anything and it was ok. Ya not good. Can't put them in un tuned Contact us for all your tuning and performance parts needs! Etuning the legacy community since 2008! Follow us on FACEBOOK | INSTAGRAM [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
Max Capacity Posted June 19, 2016 Share Posted June 19, 2016 Contact a Tuner ^^^^ hint, hint, hint for a base map. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
kustomitch Posted June 20, 2016 Author Share Posted June 20, 2016 Thanks guys I will do that Link to comment Share on other sites More sharing options...
Tuning Alliance Posted June 20, 2016 Share Posted June 20, 2016 Thanks guys I will do that I'd advise getting a comp and leakdown test before you spend anymore money. You may have hurt your motor.. bad. -Brian Contact us for all your tuning and performance parts needs! Etuning the legacy community since 2008! Follow us on FACEBOOK | INSTAGRAM [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
